Prre-requisite for NI Cert
Wow, I was just reading in the last IDPOA newsletter that NI is considering making a mate’s license a requirement for the NI DP Cert. See http://media.tmmarket.com/marex/media/pdf/IDPOA_6degrees_Issue4_Summer2010.pdf .
I knew the USCG is looking at some sort of DP license endorsement or certified training and the Manila Amendments to STCW Part B include DP stuff. I didn’t realize the NI was thinking of changing things up too. This would interesting effects on a couple of companies I can think of, good or bad.
Does OOW mean OICNW, or Management level license? There are DP crewboats that only require a 100 ton license. they are OOW, but not even close to OICNW. This ruling from the nautical institute will close the door fast on wanabees. Get started on basic training before the end of the year and you will have your foot in the door. There might be some other grandfathering, but regardless, everyone is tightening up. good luck.
Good question. I assumed it meant OICNW but I forgot there are still mates and captains out there without STCW endorsements.
What is the possibility of getting started on the basic course and being grandfathered in? I am still an AB but have the opportunity to get some time logged on a DP2 vessel. Also, anyone know what the version 1.6 is about on the NI credentials? I was on there website a week or so ago looking for a school to attend and noticed a note about different criteria.
Get the basic now!! DP time does not count until you get the basic. I went to L3 in Houston. Not cheap, where is? but they have a lot of classes so you should be able to get one that fits into your time off and not have to take off. When you go back to your boat you will be able to get your 30 days signed off since you only have to be an observer and not an operator of the system.
The rules keep changing. Previous DP time, if documented, will count towards your certificate. The NI “prefers” you follow their guideline of Class 1, 30 days, Class 2, 180 days. Time in excess of 30 days between classes count towards the 180 days. Having said all that, documentation of your time at the desk is essential. It appears that if you have started the process towards your certificate (Basic DP induction) before the new rules go into effect (Jan 1), you are exempt from the OOW rule.
The Nautical Institute has a website that spells it all out. Good Luck.
[QUOTE=Cgaptain;40578]The rules keep changing. Previous DP time, if documented, will count towards your certificate. The NI “prefers” you follow their guideline of Class 1, 30 days, Class 2, 180 days. Time in excess of 30 days between classes count towards the 180 days. Having said all that, documentation of your time at the desk is essential. It appears that if you have started the process towards your certificate (Basic DP induction) before the new rules go into effect (Jan 1), you are exempt from the OOW rule.
[B]The Nautical Institute has a website that spells it all out[/B]. Good Luck.[/QUOTE]
Any chance of posting the link to eactly where this is all spelled out? Thanks!
http://www.nautinst.org/DP/index.htm# This is the homepage. Links on the right to explore.
http://www.nautinst.org/DP/pdf/DP_OperatorCertificateJan2010.pdf
[QUOTE=cajuntugster;40570]Get the basic now!! DP time does not count until you get the basic.[/QUOTE]
They changed it. Your time before kthe classes can count now. It’s on the NI website… look it up.
Been through all these dove before but still have not found “start your basic before we change the rules”
