More Cables Cut
AIS track for Eagle S:
AIS track for the Swedish Navy ship Belos which retrieved the anchor:
Both tracks are color-coded for speed; dark red is ~0 knots.
The Finnish news also mentioned that the anchor was found at the end of the track off Porkkala (the peninsula west of Helsinki and north of the indicated position).
The grey line is the territorial water limit.
THX. But i am looking not for pictorial answer but am interested in numbers.
Lat = N yy.yy.y deg
Lon = E xxx.xx.x deg
As this item is missing in all news i have encountered in contrast with previous incidents. Such item like vsl stopping due to whatever reasons is logged both on board the stopped vessel as well as on board units representing littoral state authority doing the arrest/stoppage etc, etc.
I will check again video clip delivered by Dr.Sal
Based on HSwMS Belos’s movements, the anchor was likely raised at 59° 48.357’ N 24° 35.671’ E; it’s the only position where the vessel was stationary off Porkkala.
Eagle S’s westmost AIS data point is at 59° 48.354’ N 24° 35.388’ E after which the vessel began drifting northeast; this aligns with hauling in the dragging port side anchor chain. Shortly thereafter, it got underway again and headed directly to Finnish waters.
The Finnish OPV Turva didn’t have the AIS transmitter on when Eagle S stopped and I don’t recall reading anywhere whether it was following it or if it intercepted the tanker head-on.
Dark Fleet Tanker Might Have Damaged More Subsea Lines if Not Stopped
Finland’s National Bureau of Investigation (NBI) has found and recovered the missing anchor from the “dark fleet” tanker Eagle S, which is suspected of severing four subsea telecom cables and a high-voltage power cable in the Baltic on Christmas Day. The next step in the investigation is to determine when it came loose - before or after the authorities asked the Eagle S to raise the anchor it was dragging on the bottom
What one can catch with such a short fluke??
Fishing line??
What is the estimated max dia of a pipe or cable that can be caught with such a truncated fluke.?? any ideas??
Anchors : 02.01.2018
https://gcaptain.com/baltic-sea-cable-cuts-cant-be-accident-eu-tech-chief-says/
The European Union’s new digital chief, Henna Virkkunen, suggested the repeated damage to undersea cables in the Baltic Sea couldn’t be fully accidental, as leaders from the region prepare to gather for a NATO summit devoted to the topic
Not only in the Baltic:
Source: Nato etablerer nytt senter for å bekjempe trusler i Østersjøen – NRK Urix – Utenriksnyheter og -dokumentarer
Here is one way Norway will increase surveillance in it’s wast coastal waters and EEZ area:
New satellite will strengthen Norway’s ability to monitor the oceans
Norway’s new maritime eyes can photograph ships that do not want to cooperate with the authorities.
TECHNOLOGY: Newly developed low-light camera will strengthen maritime surveillance in Norwegian waters. Illustration: Norwegian Coastal Administration
Source: Ny satellitt skal styrke Norges evne til havovervåkning – NRK Troms og Finnmark
Seems to be happening far too often for it to be accidental. Very intresting read. Thanks for posting
That’s roughly the size of the grapple (although not the same shape) used by the cable ships for recovering the SOSUS cable. An anchor with standard size flukes would be more likely to dig in too deep.
That cable was “Quad 21”, IIRC it’s diameter was about 3-4 inches.
Can You be so kind and get the pic. of grapple used by cable ships please.
As to the relation btw the size of flukes and cable/pipe dia , the bigger the fluke , the larger the dia of grabbable pipe/cable i think.
Tanker seized by Finland over ripped cables won’t face cargo sanctions probe | Reuters
The ship’s cargo is subject to sanctions imposed against Russia by the European Union, and thus barred from importation into Finland. But because the vessel entered Finnish territorial waters at the request of Finnish authorities, the crew cannot be considered to have intentionally violated those sanctions, the Customs Office said.
So it confirms earlier suspicions the vessel was halted outside Finnish teritorial waters.
Now they say vsl was “requested” to enter Finnish waters but before it was “the FCG TOOK COMMAND” of the said vessel.
Those who think it is not a big BS pls speak up.
Tanker Seized by Finland Over Damaged Cables Won’t Face Sanctions-Evasion Probe
The smoking gun?:
Since both the Yi Peng 3 and Eagle S has been boarded and search there should be record if any devise like this was found onboard any of those vessels (or on the seabed?)
Any such report seen?
DLM has invested in its stock of grapnels, to meet purchase demand from subsea cable lay companies and ship operators. (Image credit: DLM)
Source: DLM Expands Grapnel Stock for Subsea Cable Work - environment coastal & offshore
Another supplier:
Great!!! THX . Wow, looks like the design offers much more grabbing capabilities than pictured above anchor with truncated flukes.
Wow. This dovetails nicely with the rcent innitiative of INTERMANAGER
Looks to me that nobody else but russians have some extraordinary magic & power to convince foreign flagged vsls captains of different nationalities to do criminal things .
Do you have much time working on cable ships?
Was it a cable ship that damaged the cables???
Idk what that has to do with what I asked?
I don’t have any photos. The grapple used on the cable ship I was on didn’t look like a conventional grapple.
If you hold you hand out in front of you, palm up and then curl you fingers as if to look at your fingernails, that’s roughly the shape of the working side of the grapple
If you flip your hand over and look at the back, imagine instead of being flat it was more rounded.
The actual grapple train was made up of several of these, chained together, each one rotated 90 degrees from the ones it was connected to.
It was beefy, heavy. We’d grapple for the cable in deep water, a mile or more. We’d often snag the cable on the first pass.
As far as size, each section was maybe 60 cm long, 20 cm in diameter, more or less.
