And you don’t have to get an OUPV first. It’s a matter of testing. One is Uninspected so the testing is minimal.
Negative. There is no tonnage requirement for AB unlimited, I’m not going to beat a dead horse. Read the checklists on the NMC website. There is a tonnage req for limited but not unlimited.
§ 12.403 Service or training requirements for able seaman (A/B) endorsements.
(a) The minimum service required to qualify for the various categories of endorsement as able seaman is as follows:
(1) Able seaman - unlimited. Three years of service on deck on vessels operating on oceans or on the Great Lakes.
(2) Able seaman - limited. Eighteen months of service on deck on vessels of 100 GRT or more which operate in a service not exclusively confined to the rivers and smaller inland lakes of the United States.
You just confirmed everything I just said…
The requirement is listed under AB Limited because you have to meet those requirements before you are eligible for the Unlimited. That is unless you work just on rivers and lakes. That’s right out of the CFR
Nope. You can go straight to unlimited without me ting those requirements. I assume the reason limited has the tonnage requirement is because it requires half the sea time but @jdcavo would probably know better.
If that is the case then it’s because you have to have almost twice the seatime which is still much more than the requirement for a 100T license. And considering that I’ve never seen anyone with a 100T Mates license that should be telling as well.
The reason is actually because all of the time for the unlimited AB has to be Ocean or GL. The limited AB seems to recognize smaller vessels generally in use inland, therefore the stipulation about 100 tons.
It actually always amazed me that AB unlimited requires 3 years on Ocean. That is as much or more than all the officers’ licenses. Even Master unlimited only requires 3 years on Ocean (although 6 years total).
Because they don’t exist.
They actually do exist and I had one. It is covered under the Mate LT 200 GRT license. It can be issued at 25, 50, 100 or 200 GRT depending on your sea time tonnage.
Exactly. I was being a little sarcastic with that “I’ve never seen one before”…
Makes sense. I would imagine it be pretty hard to get seatime inland over 100GRT. Aren’t most of the push boats under 100GRT? Dredges maybe? Ferries?
There is a tonnage limit for AB-Limited. There is not a tonnage limit for any other AB endorsement, including AB-Unlimited. See 46 CFR 12.403.
There is a lot of incorrect information here.
Regarding 100T.
720 days of service in the deck department on Ocean, Near Coastal or
Great Lakes waters, OF WHICH, service on inland waters may
substitute for up to 360 days of the total required service.
Regarding tonnage:
100 GRT – 180 days (25%) of service on vessels of 51 GRT or above,
OR, 360 days of service on vessels of 34 GRT or above.
11.422
50 GRT – 180 days (25%) of service on vessels of 26 GRT or above
OR, 360 days (50%) of service on vessels of 17 GRT or above.
Regarding National AB Unlimited (SCTW is different, as I found out…).
AB Unlimited – 1080 days deck service on Oceans or Great Lakes
That;'s it. No tonnage. You also need to qualify as Lifeboatman
@jdcavo when you say tonnage limit for AB Limited does that mean they have a limit to the size tonnage vessel they can serve as AB on or does it mean there is a limit to the size vessel their qualifying sea time was acquired for the document?
So my first statement above was correct when I said 720 days for 100T and 1080 for AB. I still stand by the statement that a 100 Ton license is entry level for a license and you don’t need an OS or AB to get it and you can document your own seatime. The testing for the 200 Ton Mate is even a large step up from the 100 Ton. And all of that aside none of this relates to the RFPNW in STCW which requires assessments that can’t be done aboard a boat less than 100 Tons And if I’m not mistaken have to be 500 Tons or more or in a simulator.
It refers to the service needed to get the AB endorsement. It doesn’t refer to the tonnage of the vessels you can work on once you get the AB endorsement.
For a national license, an entry level license is AB Special or AB OSV. You document your own sea time for all of these (including AB Unlimited) just like you do for the 100T. Only difference is 100T you take an 80-hour course on a broad range of topics. For AB, you need Lifeboatman, a four day course.
You are right for the SCTW licenses, I would also need Basic and an RFPNW assessment.
AB Unlimited – 1080 days deck service on Oceans or Great Lakes. 12.403
AB Limited – 540 days deck service on vessels of 100 GRT or more, not
exclusive to rivers & smaller inland lakes of the U. S.
12.403
AB Special – 360 days deck service on navigable waters of the U. S. 12.403
AB OSV – 180 days deck service on navigable waters of the U. S. 12.403
You don’t have to take an 80 hour course. That’s in lieu of taking the exam at the USCG REC. When getting my first license, 200T Mate Steersman of Towing Vessels, I only took BT, CPR, First Aid, and Radar. The radar isn’t required unless your vessel has one and the BT is only for STCW. The 80 course lets you bundle the CPR/First aid with a study prep for the schools exam that has been approved by the CG.
That’s not a license.
I don’t see how any license can be “entry-level” since you need experience in order to get one. Also, you can get a license as 500 ton mate with 720 days of sea time.
