It’s as entry level as an AB unlimited. You need more seatime for the AB unlimited than the 100T and in any case it is an entry level license for sure. Im not saying it’s as green as a first day on the job OS but a 100Ton Master upon issue is not a seasoned senior wheelman. Maybe if he runs that license for several issues without upgrading he’s not an entry level hire but he’s still got an entry level license.
Sorry, yes. Credential.
Well if that’s the case then neither is a 3M unlimited straight out of the academy.
No AB is entry level.
An AB OSV only takes like 90 days. That’s pretty green and I’d still call that entry level considering you need basically a pulse to get your OS. And there is no way a 3rd Unlimited can walk aboard an ATB or wire boat and be turned loose to steer the way the mates at our company have to steer. They are very well educated but still need to learn how to apply their knowledge. They may be able to hold a watch at sea but they wouldn’t be steering around NY Harbor. I know ABs that could steer in the Harbor better than a fresh 3rd.
About 5 years ago I had a smart, hardworking, green kid onboard. In three months he was much better than ABs with three years of experience. As soon as he had four months he got his AB OSV, BT, lifeboatman. He got AB Special, QMED and Tankerman within the next year. He’s sailing Mate now.
180 days, 120 if you’re on a vessel getting 1.5 days credit.
No job requiring any level of AB can be considered entry level since they require existence and certification.
Your splitting hairs. In the line from OS to AB then yes an OS is the entry level guy but when you consider some one with a grand total of four months experience something more than entry level that’s a stretch. When you get 1080 days you’ve got some time in. Four months isn’t long at all and there are schools that with teach you how to pass the test in about a week. It takes a few years to make a good all around AB/Deckhand unless they guy is a real hard go getter. I worked my way up as quickly as I could but experience is relative to the guy next to you. You can have two ABs with different levels of experience which is why there are different levels of AB. Depending on the vessel you’ll need an AB unlimited and an AB Special can’t meet the requirements for the billet so not all ABs are the same. It get even more so with licensing because the testing modules for an entry level license whether you go from a deckhand to 100T Master or from AB to 1600 Ton mate. Take two guys with those two scenarios and look at the differences in the requirements for approval to test. Some licenses are entry level because the vessels they work are not as complicated and the regs for the vessels are more stringent. 100T Master would be at a loss on a 1600T inspected vessel as a 1600T would be lost on a ship in the beginning. That’s why there are limitations on tonnage and increased school requirements the higher the license level. Unlimited licenses reasonable require more training as an AB Special or AB OSV isn’t as knowledgeable experience wise as and AB Unlimited. I’m not seeing how that is confusing or unreasonable. I’d call someone with 4 months in a industry still new to the industry where an AB unlimited even if he got his seatime at 1.5 days for 12 has almost two years seatime. It would take a miracle to Convince me otherwise
So would I, but “new to the industry” is not the same as “entry level”.
A 100 ton master license may be a bit of a joke here but it still requires two years of sea time so it isn’t entry level.
So an AB unlimited takes 3 years to obtain, and a 100 Ton Master takes 2 years to obtain and both can use the same exact sea time to obtain, but one is entry level and the other isn’t?
One is an entry level wheelman and the other is a senior deckhand. An entry level wheelman who can still be a deck hand but not an AB unlimited. That’s my point entry level LICENSE vs entry level RATING
One can’t operate as an AB as the other can’t operate as the master of a vessel. Apples and oranges. Neither are entry level, but you believe what you want to believe, and the rest of us will do the same.
I didn’t realize I qualify to get my 100 ton. Might go do that. Should I pay for a class again or is the USCG exam just a bunch of multiple choice memorization?
But the AB Unlimited could go apply and get approved to test for a 100T where the 100 ton guy with just enough time for that license could not apply and get an AB Unlimited because he would be short seatime days.
You “win”, dude.
You are experiencing career drift. I experienced this when I was starting in Industry in 1972. I started working on Ferries at 11. By the time I got 18, married with a kid I was obviously not going the academy route. I switched from Ferries to Tugs, to Piloting, now pretty much back to Tugs (with occasional Pilot jobs)
So (years ago) I was talking to my Rebbi, who told be the absolute best advice I have ever received: “Get as many licenses, endorsements, routes, and Pilotage as you can. Once you get ‘it’ they cant take it away.” And: “Once you get it ‘they’ cant ignore you” . So I get the frustration with different career paths, license and endorsement issues.
My only advice to you is: If you think there’s a remote chance you want to change avenues, get as many endorsements, qualifications and paperwork as soon as you can. It is only going to get harder, more expensive and difficult to obtain on your own as time goes by.
As someone earlier mentioned, you don’t specifically need anything else to work on less than 100 ton vessels in inland waters. However to make yourself more employable some companies have ‘enhanced’ requirements for applicants. Usually that is an indication that you make more $$ with enhanced credentials.
I don’t agree with the philosophy, but there it is… some HR enjoy requiring un needed endorsements, credentials just because.
I know at the company I currently work for, they only hire deckhands with 1600 licenses! Not because they are required by the CG, but because the company wants ‘bragging rights’ when applying for contracts to show customers how well endowed the fleet is with knowledge, and licenses!
Out of a 7 man crew, the only one without a masters license is the engineer!
Depends what industry you are in. Towing industry is different in license matriculation than T boat work.
You nailed it there. You can not go wrong getting everything that you can but navigating the seatime and requirement stuff can be frustrating. It’s always good to have options though…
That’s been my career philosophy across the board. Accumulating licences, credentials, training and skills is the only way to stay employable no matter what field you work in. Keeps your options open.
It’s best to do it as soon as you meet the requirements too because in the time that you put it off some new thing pops up and then you no longer meet them.
