Interesting, What type of vessel would run inland of unlimited tonnage? I’m curious… ( associating " inland " with push boats and the like). Great lakes?[/QUOTE]
The inland license does not cover the great lakes, that requires “Great Lakes and Inland”. Mississippi River is inland and ferries like the Cape May/Lewes ferry. The reason it was suggested was because it is a direct crossover to second mate AGT and is a direct crossover from 1600 ton master near coastal/oceans. So essentially you can go straight from 1600 ton master NC/ocean to 2M AGT with one application and a few tests.
I know you have the CFR’s down and like to think I do as well, but I’m having a hard time figuring out where the crossover to the AGT Master inland with just the 1,600 nc/o? Just curious to see the writing, something I should probably do…maybe an NVIC I have overlooked? Or counting the wheel man/quartermaster etc time as that in which you sailed on the 1,600.
The sticking point is time over 1,600… how the hell do you get that wheelhouse time if its out of the scope of your license? Who has quartermasters and wheelmen; maybe DPO time is being used in this context?
[QUOTE=“z-drive;108395”]I know you have the CFR’s down and like to think I do as well, but I’m having a hard time figuring out where the crossover to the AGT Master inland with just the 1,600 nc/o? Just curious to see the writing, something I should probably do…maybe an NVIC I have overlooked? Or counting the wheel man/quartermaster etc time as that in which you sailed on the 1,600.[/QUOTE]
Marine Safety Manual, Volume III, chapter 10, paragraph c, 3. (<-- from memory)
Sorry, chapter 10, section C, paragraph 3. And it reads:
[QUOTE=“z-drive;108395”]The sticking point is time over 1,600… how the hell do you get that wheelhouse time if its out of the scope of your license? Who has quartermasters and wheelmen; maybe DPO time is being used in this context?[/QUOTE]
You don’t need time over 1600, just over 200. They put a restriction on your license then you get time over 1600 to lift that restriction. You can theoretically go all the way up to Chief Mate with a tonnage restriction if you want to…
(You can also use ATB time to count as tonnage because you can count the barge tonnage for part of your sea time on a 2:1 basis.)
[QUOTE=z-drive;108395]…I’m having a hard time figuring out where the crossover to the AGT Master inland with just the 1,600 nc/o?.. [/QUOTE]
I’m not sure there is one, particularly to or via 2nd Mate AGT. I wasn’t able to find one, but only searched briefly. I’m not currently able to make a conclusive search, so perhaps someone else can provide specific citations?
[QUOTE=“jdcavo;108413”]I’m not sure there is one, particularly to or via 2nd Mate AGT. I wasn’t able to find one, but only searched briefly. I’m not currently able to make a conclusive search, so perhaps someone else can provide specific citations?[/QUOTE]
