Holy Chu! Recall the 2-pipe anomaly? It’s back [from LATimes 6-29]…
… "The gushing BP oil well is a mystery still unfolding, and late last month, a team of scientists from the Energy Department discovered a new twist: Their sophisticated [B]imaging equipment [/B]detected not one but [B]two drill pipes, side by side[/B], inside the wreckage of the well’s blowout preventer on the bottom of the Gulf of Mexico.
[B]BP officials said it was impossible[/B]. The Deepwater Horizon rig, which drilled the well, used a single pipe, connected in segments, to bore 13,000 feet below the ocean floor. But when workers cut into the wreckage to install a containment cap this month, sure enough, they found two pipes. …
This 2-pipe anomaly in sheared BOP/riser demands confirmation as either true or false. Did BP save lots of time/$ by not removing some unwanted pipe-thingy?
hell is going to freeze over, by the time I try to respond,and then get a’’ add’’ moment,what are we talkin about?.."jimminny crickets,for you blister, in place bleepidy bleep. Anyways…good to be with you guys,
Thank goodness, alcor is on a 2 week job run, because if he, and CMI were going at it…I d really feel for the wife, and kids at home,Can you imagine?? O my gawd…police cars outside, on the front lawn,with alcor, and CMI decking it out…
Let’s see if I can post here now, and howdy everyone if I can. here goes…
Well whoot! I posted! Thanks to everyone that helped me with the redirect and the workaround. Ok, so, it’s a bit crippled but it does seem to work.
I’m trying with Firefox now. Let’s see if it’s faster. edit: Zomg, way faster. Still get the error, but, way faster. NOL, I didn’t realize you stay up this late… I would have contacted you last night!
