Not sure if such thread will spark attention but at least I will give it a try.
DNV_Energy_Transition_Outlook_Executive_summary_2022_compressed.pdf (maritimecyprus.com)
Full report is here:DNV_ETO_main_report_2022_1112022.pdf - Google Drive
DNV has launched new guidelines for Onboard Carbon capture Systems on board ships:
DNV`s guidelines were published in September and can be accessed here.
Source: DNV has launched new guidelines for Onboard Carbon capture Systems on board ships
More “paperwork” required on arrival in Europe:
May not affect ship’s Master and crew, though.
Question for you Spowiednick - on the large container ships you sailed on with beams closer to 48 meters, did you have to carry any ballast during normal service?
Thanks buddy … so really not much difference from the 1st gen post panamax vessels (40 m beam). Fortunately in my experience we had sufficient cargo both ways and minimal to zero ballast.
Far cry from the narrow bodies … always carrying 3-4k ballast in the DBs. Slow death of the tanks.
PS: Lower aft peak tank was locked in treated fresh water.
PPS: No SW ballast on the moored FPSOs.
The 16 OSPAR contracting parties have agreed to phase out discharge from EGCSs in coastal waters of the European north-east Atlantic. Restrictions on open loop discharge are to take effect from 1 July 2027, and closed loop discharge from 1 July 2029. Read more about the ban in this news and on what to consider if EGCSs are an essential part of your SOx emissions compliance strategy.
Recently changed from DNV to BV.
What a ball ache.
Every cupboard, locker , storage space is no longer any of those.
All of the stuff ended up piled on the deck.
25 years of no problems and then BV turn up.
Explain to me why DNV treat Class 9 DG differentrly to what BV do?
I can’t explain that, but here is DSV’s take on DG Class 9:
For 25 years, under DNV, Class 9 could (mostly) go on the maindeck.
Now, under BV, they must go top deck only, regardless.
Makes no sense.
The International Maritime Organization (IMO) has adopted significant amendments to the International Grain Code through Resolution MSC.552(108)1, which will take effect on 1 January 2026 and will be applicable to both new and existing ships. These changes introduce a new optional loading condition aimed at improving flexibility and safety in the carriage of grain in bulk.
Amendments-to-International-Code-for-the-Safe-Carriage-of-Grain-in-Bulk.pdf (490.3 KB)
The IMO has introduced SOLAS Regulation II-1/3-13 through Resolution MSC.532(107), setting new requirements for lifting appliances and anchor handling winches. These updates will take effect on 1 January 2026, ensuring enhanced safety and operational standards across the maritime industry.
maritime.lr.org/l/941163/2025-07-02/chq5c/941163/1751462044SHBe9iRG/12_25_class_news.pdf
Have never been under BV but to get an answer hit : " explain to me why dnv treat class 9 dg differentrly to what bv do? " in AI mode and it will give you all you need.
According to some pundits and scaremongerers cyber threats against ships and companies are on the exponential rise.
Wonder how safe are this electronic formats below against cyber frauds done by bad actors acting for profit.
Fraudulent paper licences have been present as long as I remember . Interested what kind of precautions are introduced by issuing parties .
