I have my Chief Engineer Limited (1600 ton) no horsepower restrictions. My OICEW has a 500 ton limitation. My question is, if I get NVIC 15-14 completed will that remove the 500 ton limitation on my STCW? This has been such a pain in the ass!
I do not hold a 3rd A/E, I have a DDE AHP so do I need to apply for an Assistant Engineer Limited?!
Why was your OICEW limited to 500 GRT? Did you hold DDE at the time you got it?
Also, if you have Chief Engineer-Limited, you can’t serve on a vessel over 1,600 GRT, so you’ll probably not get the limitation removed entirely, it will likely have a limitation to 1,600 GRT.
