You may have luck with a protest of the question; if you provide the correct mathematical solution to the problem and your associated work, point out that your solution lies between two of the provided answers and then explain why you selected the answer marked on scantron. Assuming the protest procedure is the same as it was 20 yrs ago, you can protest as many as you like prior to submittal of your answer key. And protest the pore quality of the photocopied diagram if you feel that is causing your margin of error. Practicing the skills and each of the different types of questions using Lapware was most helpful for me, to confirm my skills were sharp enough to get the provided answers.
Shipncs
21
Related topics
| Topic | Replies | Views | Activity | |
| Chart Plot changed | 51 | 5683 | April 3, 2023 | |
| Examinations for deck | 7 | 822 | April 2, 2022 | |
| 3rd Mate Exam Pass Rates Plummet | 103 | 8431 | April 11, 2023 | |
| 500/1600 Ton Master Inland Exam | 9 | 1637 | April 4, 2021 | |
| Anyone sit for Chmate/Master upgrade lately? | 17 | 2198 | January 26, 2012 |
