[Technical Architecture] S.K.O.O.G. SCSL: Industrial-Scale Atmospheric Water Generation (Open Source)
To the Naval Architecture Community,
I am presenting a Defined Engineering Architecture for a biomimetic offshore infrastructure designed to extract freshwater directly from the air. With 3.6 billion people currently lacking stable access to water, we need solutions deployed with the same engineering certainty we apply when building a bridge.
Note on Technical Substance: This is a specific engineering framework based on established thermodynamic principles and industrially proven materials. The physics and logic are transparent, published, and open for review.
The Skoog Capillary Sweating Liana (SCSL) is shared under a Creative Commons Attribution 4.0 International License.
1. The Concept: Biomimetic Industrial Condensation
The SCSL mimics the hydraulic and thermal behavior of a tree on an industrial scale, utilizing natural thermodynamic processes to eliminate external energy needs.
Cooling Source: A 1,000-meter closed hydraulic circulation loop using HDPE (PE100) pipes to access the constant 4°C deep-sea thermal gradient.
The Motor (Water): Ocean wave energy drives a flexible composite bellows (wave pump) to maintain circulation. Since the system is a closed loop in equilibrium, the energy required for rotation is minimal, as there is no static head to overcome in the traditional sense.
The Motor (Air): A black solar-thermal chimney drives natural updraft to increase air circulation across the cooling surfaces.
The Matrix: A 500 m² passive capillary matrix utilizes the “Uddeholm Effect” to create a continuous liquid film. The condensation process itself releases significant latent heat, which is strategically recovered within the system to further enhance the thermal drive and condensation efficiency.
2. Environmental Advantage: Zero Waste Products
Unlike traditional Reverse Osmosis (RO) desalination, the SCSL has zero byproduct discharge.
Atmospheric Extraction: The system condenses ultrapure freshwater directly from the air; it does not process or concentrate salt from the sea.
No Chemicals: The process involves no mechanical filtration, consumable filters, or chemical treatment cycles.
3. Engineering Reality: No Pumps, No Electricity
Self-Pressure Discharge: Solar energy expands the collected condensate (0.43% volumetric expansion), generating the hydrostatic pressure required for land delivery without electrical pumps.
Target Yield: Optimized for ~12,000 liters per day per unit.
Maintenance: Integrated Skoog IAKKS (Active Ceramic Coating) prevents biofouling via kinetic micro-vibrations powered by a LiFePO4 buffer. (Also open source)
4. Implementation & Call to Action
This system is engineered using industrially proven materials. Because the global water crisis is urgent, the development strategy prioritizes direct industrial assembly and field validation rather than prolonged laboratory isolation.
A Request to the Community:
Out of respect for the 3.6 billion people currently suffering from thirst, I ask that you read the technical documentation before offering critiques. This architecture is open for a reason: to be improved and implemented immediately.
Once you have reviewed the material, I invite you to contribute positively to the discussion. Now that a viable solution to this global crisis exists, let us discuss how to refine and deploy this system to ensure clean water—a fundamental human right—reaches as many people as possible.
Technical Source of Truth:
Detailed Technical Report (Zenodo DOI):
Göran Skoog
System Architect | S.K.O.O.G. Architecture | SOMT
