Qualifying for Able Seafarer-Engine 46 CFR 12.607 (c)
Hopefully I’ll have my RFPEW and QMED with Junior Engineer, Electrician/Refrigeration Engineer, Pumpman, and Oiler in hand by October or November. As long as I have those it seems that I would comply with paragraph C? I’m reading C as saying that as long as I have my QMED and RFPEW before 2017 I’ll be given the AB-E? Because C seems to directly conflict with B with it’s 12 month requirement. Anybody run into this?
[B]§12.607 Requirements to qualify for an STCW endorsement as rating as able seafarer-engine.[/B]
(a) To qualify for an STCW endorsement as an able seafarer-engine, an applicant must—
(1) Be not less than 18 years of age;
(2) Meet the requirements for certification as a ratings forming part of an engineering watch (RFPEW);
(3) While qualified as an RFPEW, have seagoing service in the engine department of—
(i) Not less than 12 months; or
(ii) Not less than 6 months and have completed approved training; and
(4) Provide evidence of meeting the standard of competence specified in Table A-III/5 of the STCW Code (incorporated by reference, see §12.103 of this part).
(b) Until January 1, 2017, seafarers will be considered to have met the requirements of this section if they have served as a watchstanding Qualified Member of the Engine Department (QMED), junior engineer, oiler, fireman/watertender, deck-engine mechanic, or engineman in the engine department, or as an RFPEW for a period of not less than 12 months within the last 60 months prior to application.
© Seafarers holding a rating endorsement as QMED, junior engineer, electrician or electrician/refrigerating engineer, pumpman or pumpman/machinist, refrigerating engineer, or machinist before January 1, 2017, will be eligible for this endorsement upon showing evidence of holding an endorsement as an RFPEW.
(d) The Coast Guard may exempt an applicant from meeting any individual knowledge, understanding, and proficiency required in Section A-III/5 of the STCW Code. These exemptions must be approved by the Coast Guard based upon vessel type. Under these circumstances, the endorsement may include a corresponding limitation.
(e) Except as provided in paragraphs (b) and © of this section, seafarers with the following national rating endorsements will be eligible for this endorsement upon completion of requirements designated in this section:
[B]Table 1 to §12.607(e)—STCW Endorsement as Able Seafarer-Engine [/B]
[TABLE=“class: gpotbl_table, width: 100%”]
[TH=“class: gpotbl_colhed”]Domestic QMED
endorsement[/TH]
[TH=“class: gpotbl_colhed”]Additional sea service for AS-E[/TH]
Engineman
None.
Deck Engine Mechanic
None.
Electrician
6 months.[SUP]1[/SUP]
Refrigerating Engineer
Pumpman
Machinist
[/TABLE]
[SUP]1[/SUP]Service may be reduced to 3 months if training has been completed as part of an approved training program.
Just a side question to your question. Are you coming from Seattle M
Well here’s what I’ve determined: NVIC 18-14 cites 46 CFR 12.607© which basically says that if you hold a QMED, RFPEW, and BST before January 1st, 2017 you will be qualified for AS-E.
B Seafarers holding a rating endorsement as QMED, junior engineer, electrician or electrician/refrigerating engineer, pumpman or pumpman/machinist, refrigerating engineer, or machinist before January 1, 2017, will be eligible for this endorsement upon showing evidence of holding an endorsement as an RFPEW.[/B]
NVIC 18-14
https://www.uscg.mil/hq/cg5/nvic/pdf/2014/nvic-18-14.pdf
