Allwyn have you talked to any engineers that want to take on the day to day running of a ship along with running the engin room?
<!-- / message –> <!-- controls –> [I]
[/I]Jem, if you are referring to provision management, accounts, accommodation housekeeping, presentation of documents to CG/ Immigration etc frankly no. Neither i think Chiefs would be interested in this stuff. IMHO the Captain also should not be doing this. This is clerical stuff. Most company procedures manuals lay out quite clearly what is expected in daily running of ships. Any executive position should expect to be competent to macromanage and not micro manage such tasks delegated to someone.
No were in the above did I even inference that any officer should be micromanaging, but I knew that’s were you would take it. The whole reason that an engine dept was put on board was because it was becoming to much for the Master to keep up with. Now you essentially what to go backwards and saddle a guy with enough responsibility already with even more responsibility that was deemed to much for one guy.
Maybe this is were my experience from just running small boats in the oil fields, but who’s job is it to makes sure all this clerical stuff is done at the end of the day?
Who’s job is it if it isn’t the captains to make sure that all the T’s have been crossed and the I’s dotted?
Are you saying that when any of the above that you listed doesn’t go off as planned you’re not calling the master to at least know who you should be talking too, and if he goes “I don’t know” it’s a perfectly acceptable answer?
And still at the end of the day when something does go wrong and the CG has to be called the first person they want to talk to is the Master, and I can tell you from personal experience that pointing at someone else and saying they were in charge of that particular activity doesn’t absolve you from what happened.
I think that you forget that even the laws are written that run completely contradictory of what you are proposing.
[I]Seen another way however the third mate is now part of a team which consist of three vessels (the ship and two tug) each with its own crew which must pull the ship off the dock in restrcited waters get swung around and started down the channel. An operation whcih has tripped tugs and drown and kileed crews. A good crew makes it look easy but the fact that sometimes something rips loose and kills or injures someone and sometimes it does not is not simply a matter of luck. [/I]
I have personally managed spring and breast lines amongst tugs, floating docks and the ship several times without the presence and help of master, mates or deck officers, because none were present. I understand and appreciate hazards involved in pulling and straining ropes. While they require good situational awareness, they by no means require high technical skillsets. Implies a person who’s done even very basic school and posseses high situational awareness, can carry out such tasks as competently as someone who posseses a Masters in some field of Strength of Materials. So without altering the risk factor anything, i can conveniently put a much lesser qualified, but situationally aware person also in charge of actual operations as far as rope handling goes
Congratulations you got lucky. 99% of the time nothing happens, but that 1% is the one that fucks you over. That 1% is only lowered by having experienced guys in charge.
Whats even more telling is this.
You would rather pay for the bare minimum instead of stacking the odds in your favor of everything running more smoothly and pay for experience.
Again it has been said by Capt. A, Capt. Fran, my self, and others. Your company is suffering from bad communication, and what sounds like some bad hiring decisions and policy’s from H&R. Instead of trying to reinvent the wheel why not try and fix it first?
I’m sure your not the first to come up with your idea, so how come it hasn’t been implemented? The big reason is that at the end of the day there are thousands of things that can happen on the open water were the command system works best and is proven to save lives. So while even if you’re system could save your company money, is it worth the risk to human life that it could impose?
As much as I dislike your idea, I will give you props for bringing it here were it can be vetted by those who it would impact most. I just wish some of the engineers around would way in on this.
