[I]Here you have described a Master supervising, which is his job.
[/I]Apologies, but the Master is not qualified to supervise just any job on board. There are errors being made on this count. The Master cannot directly supervise a whole lot of things on board. You do not seem to understand the incident: The Master and fitter were together when i found them in he drizzle.
[I]So if your engineer type who is welding in the rain doesn’t have enough experience to stop the job[/I]
The fitter was under the mate. Captain hired him and since no signature is above the Captains, he felt a 5 minute arc welding job could be done in the rain. Wrong, it should not have been done. There was no tearing hurry to install he LRIT frame support anyways.
[I]
This may be one of the most important concepts of this entire discussion.[/I]
There is no concept here. Simply the management rightly concluded that Masters at our disposal do not have adequate knowledge to supervise such work. Their signatures though mandated by law, hold little guarantee for our Management against casuality prevention and hence claims. So we had to rope in Engineers to sign HW permits, since they understand the risks involved and the chances of such errors would be minimized. This incident was documented internally by he company.
[I]A critical piece that is missing in your understanding of the nature of command authority is the fact that you’ve never held it.[/I]
Command Authority systems of management are obsolete everywhere. Command authority works under exremely close supervisory tasks. Not remotel controlled ones. Dictators like Saddam were full responsible and in full command. They ran a bad ship. Transparency, so essential to good operations and management systems runs counter to the Command Authority that you refer so subjectively, and has been pointed so by some posters here. However, on the same vein i can counter question how, you as a Master would support a Chief Engineer and his team working on trouble shooting a crane where a situation from an intermittent failure to complete failure in luff/slew operations is underway. Since the crane serves 2 hatches, if it fails we incurr costs over $300,000 getting a sore crane to discharge the rest of cargo.
Such instances we pressure the Chief, not the Master. So question again, what would you do as a Master? How would you assist the Chief in the troubleshooting or otherwise? Do you have experience in troubleshooting engineering systems under a time frame? Or would you use your command authority to get it done somehow?
[I]They’ve got plenty to keep them busy and they are delegated an enormous amount of responsibility and authority by the master anyhow.[/I]
The Master is not delegating any authority to the Chief Engineer. The Chief Engineer comes armed with that authority and responsibility over all ship machinery and equipment under the ISM code. He wears the same number of stripes on his shoulders that the Ship Master does. You certainly are not comprehending the pressures that troubleshooting engineering systems entail on the Chief.
