MARPOL Annex II – Recording Shore Removal of Cargo Residues Before Mandatory Prewash
Good day, fellow mariners.
I would appreciate advice from chemical tanker Masters, Chief Officers and PSC inspectors regarding the correct Cargo Record Book entry for the following operation.
Before the mandatory prewash, a shore cleaning company removed the remaining cargo residues directly from the cargo tanks using shore equipment via the tank tops. No tank cleaning was carried out by this company. A Waste Receipt confirming receipt of the residues is available on board.
The vessel subsequently carried out the mandatory prewash, and the resulting prewash slops were handed over to a separate shore reception facility.
Would Code K (Additional operational procedures and remarks) be appropriate for recording the initial removal of cargo residues, or should Code E or another code be used?
Has anyone encountered a similar case during a PSC inspection? I would particularly appreciate references to MARPOL Annex II, the relevant CRB instructions or PSC guidance.
Thank you in advance.
