JRC Weather Fax print out not clear
Hi all
Trying to sort out the timer function setting on our JRC JAX-9B weather fax, and having no luck.
Can anybody shed any light on how to amend the the current state of the weather map print out as can be seen from the attached photo? It’s picking up the transmissions as the correct time as set in the schedule timer, however it seems to be printing one small section, stopping and then starting again.
We have tried placing the machine in auto timer mode and also in manual timer mode trialling different IOC settings and scan (drum speed) settings.
Thanks for any help :slight_smile:
hi there sir we have the same problem i hope you already have the solution? await your reply thank you
