Issue with Marinfloc CD5?
Hi all,
Has anyone got any experience with the Marinfloc Emulsion Splitting Unit CD5?
Normally it is operating okay but today it has just randomly ran into some troubles.
When starting it initally goes to through the feed pump and descaler and then when it reaches the recirculation tank the feed pump stops, the drain pump starts operating at high pressure and the pressure increases alot inside the recirculation tank and the descaler tank and will lift the pressure relief,
It will not go through the flocculation tank or filters,
Weve checked the air vents, feed pump strainer, checked if the high and low level sensors inside the recirc tank are working and not stuck, the temperature, checked all the valves are in the correct positon,
Im just wondering if someone has ran into something similar and if so what they did?
