A question:
Has anyone ever heard of a well where a barrier has been established, displacement performed and second barrier established…to find that when the new rig resumes the well, full well pressure is experienced on drilling out the upper barrier?
Or, what about the case where two tested barriers fail after the vessel has moved off location? It’s very possible. I believe it has happened.
The difference is that not every well has the potential flow rates the Macondo well provided, mainly due to the casing allowing the well to flow, unhindered by normal bridging expectations (one of the reasons experts came to the conclusion that the flow was from the casing and not the Annulus…if the Annulus side had failed the normal experience is for bridging to occur, in which case, the well would ‘self-seal’. Many commentators on this site missed this point in the first 6 weeks of the well’s ‘Flow’, myself included. And they didn’t come back afterwards to answer for early conclusions, perhaps understandable when you consider many were prominent experienced engineers with much to lose based on their very early conclusions, something which has set the ‘temper’ for the investigation. I should point out that we were ALL deceived at this time, and should our understanding of the well’s failures have proved to be correct BP would have hung).
