[QUOTE=CaptKrunch;184271]I have the command experience and am in no way opposed to either route. For obvious reason I would want to go the most efficient method possible. Thank you for your reply.[/QUOTE]
I was not referring to command experience on a OSV restricted license. I was stating in terms of a Master unlimited, if there was any intention on using it (in an unlimited manner meaning any sector in the industry), chances are you will not get that particular job without having served on that particular license. Like you have done, and we all have done, proving yourself at a lower level before advancing to the next step is a little higher in the pecking order than what is stated in the MMC. Now in terms of just to get the Master license as a personal achievement with no intention to move anywhere, staying in the same sector, and just the upgrade alone within the confines of an OSV (which is possible - been there - also I was the first to get a large OSV license in '98), the most efficient route is to study your ass off - period. Either way, there is a test at the management level.
My advice:
Study your ass off (there is a test, reemphasized).
Apply for Chief Mate unlimited, then go pass the test once approved to test.
Once the test is passed, call the evaluator, and state that you believe you should be issued a Master license due to the information submitted. This is a very short conversation to be had. Chances are, the Chief Mate will be issued and you will get it that much earlier for the sea-time clock to start.
Long way around:
Apply for Master, I do not see that being approved, but I will go along with the crowd for now.
If the Master is not approved, then your application is stuck in evaluation and an extended conversation/reconsideration process, yada, yada, possible denial.
If the Master is approved, good for you, but this was not ever certain to begin with and very doubtful,  but by taking my advice, you would have been in the testing room with 100% chance versus 99/01.
In the end, the conversation can take place on the back end without inhibiting the test taking (as mentioned, that is the end game). Actually, you should be able to pass the test now if clearly motivated.
Hopefully, recently you got enough sea-time on the 2nd Mate to just now qualify for Chief Mate. If you have been sitting on the 2nd for a while, the one year saved by skipping Chief Mate is barely worth the conversation.
[QUOTE=CaptKrunch;184235]So what does this mean for someone who has held the 6000 and 10,000 Master OSV as well as 2nd Mate Unltd? No seatime as Chief Mate. Only as Master. Do I qualify to test and get Master Unltd or must I get Chief Mate first?[/QUOTE]
Chief Mate
