Hello and greetings from TheNavalArch!
We’re pleased to publish a new article titled ‘Draft Surveys - Methodology, Calculations and common errors’.
A draft survey is an effective tool for the correct determination of the cargo loaded/discharged from/to the transporting unit. However, there are several intricacies involved in both conducting the survey, and the follow-up calculations. This article explores the topic in-depth, with detailed explanations of calculations involved.
Article link:
Regards
Team TheNavalArch
