Does 200 ton OICNW trump AB RFPNW?
#1
What if:
Say a person has an AB but no RFPNW.
Add to that the AB also has a 100 or 200 ton OICNW on the STCW.
Can the AB use the 200 ton OICNW to stand a watch as AB on a larger tonnage vessels? If so, what is the pecking order for OICNW and RFPNW?
Thanks,
Joel
#2
I think you have to have 500 Ton to bypass RFPNW, but then again you need 90 days as an AB to get your 500T. Not 100% sure.
#3
It depends on the “Limitations” noted on your certificate. If the authority of the OICNW is limited to 200 GRT, then you can’t use it to serve as RFPNW on a vessel greater than 200 GRT unless your certific ate also has RFPNW on it without a tonnage limit.
You have a an STCW certificate (a separate certificate with your picture on it, not words on your license) for OICNW not more than 200 GRT?? What REC did you get it from?
#4
Hello Mr. Cavo:
I have a STCW page.
On it it reads:
“…Master 50 grt NC/100 grt OICNW (Mate)…”
I submitted my original application for MMD AB and the above Master at Portland, OR. They sent it off to Virginia. This was mack in AUG 20008.
Joel
