Unexpected mobile data charges when entering ports — how do crews handle it?
I’ve seen several cases where crew phones automatically connect
to local mobile networks when vessels enter port and start consuming
data in the background without anyone noticing.
In some situations this resulted in significant roaming charges
before the crew member realized what was happening.
How do you normally deal with this?
Airplane mode?
Turning mobile data off?
Dual SIM?
Something else?
Curious to hear how others handle it.
T-Mobile International Data Plan. No extra charges & it has worked for me in over 20 countries on 6 continents without fail.
I keep my phone in Airplane Mode on the ship unless I’m actively using it, and I also turn off automatic updates. Androids, and probably iPhones I assume, also have “low data” modes where you can prevent apps from automatically pinging servers - think email, messengers, etc. You can probably use ship wifi while the phone is in airplane mode too if you don’t want to connect to cell networks. Finally, you can usually go into your SIM manager and turn off data roaming.
There’s no substitute for dual sims. Esims are particularly useful IMHO. I use and recommend Airalo. Don’t leave home without it.
One thing I’ve noticed is that most of these methods rely on manual action. Phones sometimes reconnect automatically when:
  • leaving airplane mode
  • switching between ship WiFi and cellular
  • after updates or restarts
So even if someone is careful, background data can still start flowing without noticing.
Has anyone seen a more automated way to prevent unwanted network connections when entering port?
And no need to mess with SIM Cards either.
T-Mobile with free roaming just about everywhere. Then no need to even think about it.
Interesting to see how most solutions still rely on manual actions (airplane mode, disabling data, dual SIM etc.). In practice, the issue often happens not because someone doesn’t know what to do — but because during port operations it’s easy to forget.
After seeing this happen multiple times, I started working on a more automated approach that blocks data access when the phone connects to unwanted local operators and restores it when back to a trusted network. It removes the need to constantly manage settings manually.
Still early stage, but curious — would something like that be useful onboard?
You can always turn off Data Roaming.
Yes but still there is a chance to forgot about it.
LOL. You only have to switch it once.
Oh yes, my bad
why not go ahead. Sounds interesting . Hands free “ network and data manangement app” for mobile phones.
Actually, I started experimenting with a small Android prototype around this idea to automate network control when entering ports — mainly to see if it can really reduce accidental roaming/data usage. I’m still learning from real feedback, so if anyone here has some thoughts on what would make something like this genuinely useful onboard, I’d really value the input.
Again, T-Mobil! They give you free international data and texts in most any country you’ll go to. Nothing to remember to do, it’s automatic. Data will be slow, but oh well. For $5/mo more you can get higher speed data. The only caveat is they may cut you off if you’re several months in a foreign port. But then, still no worries, as you’ll have no service, just like airplane mode automatically, until you get back to the states.
I have read all responses posted before this response, and T-Mobile will be my choice. Thanks for the info.
Thanks to @tugsailor also.
Appreciate all the input here — interesting to see how most current solutions still rely on manual actions or specific roaming plans.
From what I’ve observed, the issue often isn’t that crew don’t know what to do — it’s that during busy port operations it’s easy to forget for a few minutes, and that’s enough to trigger background data usage.
I’ve been experimenting with a small Android prototype that tries to automatically block data when connecting to unwanted operators and restore it when back to trusted networks.
Still early stage and learning from real-world scenarios.
If anyone here would be open to testing something like this onboard and giving honest feedback, feel free to message me.
One thing no one has mentioned that many of my shipmates tried that turned out to be too good to be true was Google Fi. Simple, inexpensive phones with very reasonable monthly plans. But everyone I’ve known that used them eventually gets locked out after 2 months of being overseas. If a mariner works in overseas oil fields, say 4 or 6 weeks at a time or only out of the country sometimes, then 2 unlimited phones for $80 a month might be worth a try? But I’m sticking with what I know that works which is T-Mobile. I’m too old to risk communications with my family & lose of investing online because I wanted to maybe save $30 a month on a different phone service.
I mean, unless you’re going to tell the carriers to change how their plans work, anything you want to do with your phone will require you to do something with your phone. Turning on low data mode, turning off data roaming, going into airplane mode to only use wifi while on the ship are all once-per-work-tour tasks. If a crewmember isn’t capable of managing that, I’m not sure I’d want them on my ship at all :stuck_out_tongue:
Thanks for all the insights here.
I’ve started collecting real cases and practical tips about onboard internet and roaming risks for seafarers in a small Telegram channel.
If anyone is interested in following the topic or sharing their experience, feel free to join.
