Those boats are shallow forward and draw more aft. It could be they expected a easier pull if turned. Pull the only option first responder had.
Having said that and responding to several similar groundings first rule is don’t make the situation worse. She was not likely to break up inside the calmer outer bar. Better let the surf calm down tide go out dig her out and pull next high tide.
Real question how could all systems fail together. Redundancy comes from not being interconnected. Both engines and generator same time ? sounds like a serious design flaw
That makes sense and further highlights the failings of reliance on new technology without experience or common sense. You see outboard center consoles far off shore, two engines one fuel tank .
If it’s electric, controlled from the helm position, total loss of power would explain it. Personally, had I been aboard, would not have gone, or asked crew to go onto that bow in rough seas and manually drop the anchor. Better to let her drift onto a sandy beach than loose a life.
I am going to guess that the windlass was powered by the ships generators. It’s quite possible that the activation of the fire suppression system could have automatically shut down anything running in the engine room like the mains and the gensets. No gensets, no power.
I had to look it up too. Seems like an instagram for fishing charter skippers that has turned into a lifestyle brand. Oh and you too can be a licensed captain by following their links!
Anchor was jammed. From a different post, emphasis mine:
UPDATE: STATEMENT BY @vikingyachtcompany REGARDING THE VIKING 92 BEACHED IN DELRAY, FLORIDA
“On November 3, 2023, a 2017 Viking 92 Open Bridge Convertible (92 C) departed Palm Beach Inlet en route to Fort Lauderdale, Florida. Within an hour of departure, the 92 C encountered a fuel interruption to the generators and then main engines, at which point the 92 C lost power. It was set adrift as the captain and crew tried to resolve the problem. The crew tried to deploy the anchor by releasing the brake, but unfortunately the devil claw was still attached. It subsequently was lodged into the deployment chute rendering the anchor unusable. The 92 C came to rest on the shore in Delray Beach, Florida.
The vessel is now at the Viking Yacht Service Center safely blocked in our Riviera Beach yard since Sunday night. After our technicians inspected the 92 C, they determined that the incident was not the result of manufacturing or design error and that the damage was minimal. Once we receive the needed parts and materials, we expect to have the boat back fishing hopefully by the New Year.
Most importantly, the captain and the crew are safely ashore with no incident.”
Dust left in the fuel tanks from the manufacturing process is by far the most common cause of engine trouble on new built yachts. Any delivery crew worth its salt familiarizes itself thoroughly with the filtering system and ensures that there is an ample supply of spares on board. Even that may be insufficient, though. There are stories out there of delivery crews going through cartons of fuel filter elements in a matter of hours before ending up dead in the water.
After any work on the tanks, especially fitting new ones, I always do a thorough shakedown in the roughest seas I can find (within reason of course), then changing filters before delivery. I have a few favorite spots around the fjord where tidal conditions allows this in fair weather. Doing this is far easier than trying to explain to the owner that his systems must be regarded as unreliable until the boat has experienced a bit of weather and had the prefilters replaced.
As for deliveries, I always make sure I can replace prefilter elements in a hurry, whether the boat is new or old. That’s just common sense.
As for yachting grade windlasses, they are not like the ones y’all are used to. Quite a few don’t have a free fall function and must be hand cranked with a winch handle (which is probably not on board) in case of power loss. They are also often mounted in inaccessible locations, and owner/operators are almost universally unfamiliar with any emergency procedures.
During my many final surveys in the bowels of newbuild ships prior to delivery, dwt up to the hundreds of thousands, I have regularly found, with dismay, portable ladders, bits and pieces of scaffolding, tools, soiled overalls, brooms, empty paint containers, puddles of urine, faeces, all manner of dust and grit and, once, a discarded industrial vacuum cleaner complete with a hundred metres of electrical extension cord. All discovered in ballast tanks, forepeak tanks, aft peak tanks, cargo tanks, slop tanks, fuel tanks, void spaces and other nooks and crannies on board never to be seen again by human eyes. Naturally, condition rejected, until such time QA conducted their own pre-check. As expected, such a result would invariably raise a hullabaloo from the Yard, hand-over delayed,
As far as the excreta was concerned, I suppose when you gotta go, you gotta go - spending half an hour exiting a tank likely might compromise clean under garments! Wags on some crews would post a detailed warning at the gangway inboard headlined “Turd Alert”, updated according to circumstances.
The fact is that In difficult situations captains might be forced to take tough decisions!!
I usually don’t like to jump to conclusions before having a detailed investigation or report with input from captain and crew
Although the boat don’t have a bow railing which made it difficult to manually deploy an anchor in rough weather, but even a free anchor from the strain might’ve helped!!! Or maybe not?
Hopefully a detailed report will be issued soon so all of us can learn from this incident and take further measures to avoid such incidents
