[QUOTE=bunker305;118226]I’m not seeing in the cfr’s how a dde, which is limited to 500grt goes to a 3000 ton level by simply adding on the chief osv endorsement, not the chief limited but the chief osv endorsement…[/QUOTE]
You need to stop thinking of this as one endorsement. They are two separate endorsements, so there is no “roll over.”
[QUOTE=bunker305;118226] …everywhere in the cfr’s a DDE is limited to 500 tons, but once you add the chief osv endorsement, which again says no further testing or assessments required, and whatever horsepower DDE that person has rolls over to his chief osv ticket along with the added tonnage. I understand the horsepower rolling over (1000,4000,unlimited) but why doesn’t the tonnage restriction remain the same (500grt)? [/QUOTE]
The DDE endorsement (license) doesn’t “go to a 3000 ton level by simply adding on the chief osv endorsement GT is limited to 500 GRT.” Chief Engineer (OSV) is a separate endorsement (license) that is only good on OSVs (any OSV). The restriction of DDEs to 500 GRT is in 46 CFR 15.915(a). There is no similar regulation that restricts a Chief Engineer (OSV) endorsement to vessels (OSVs) of a particular tonnage, but it is only valid on OSVs. Having two separate endorsements as DDE and Chief Engineer (OSV) doesn’t allow you to work on a vessel over 500 GRT that is not an OSV.
[QUOTE=bunker305;118226] …explain to me how a 500grt ticket goes to a 3000grt, without the need for additional sea time or tests. [/QUOTE]
See above about a DDE endorsement “growing” to 3,000 GT. There is no need for additional sea time for someone holding DDE to add another (different) endorsement for Chief Engineer (OSV) as the sea time for DDE unlimited and Chief Engineer (OSV) are the same. If you have enough time for one, you obviously have the sea time for the other. As far as no exams, 46 CFR 11.950 requires an applicant for DDE or Chief Engineer (OSV) to be tested on certain subjects, and these are substantially the same for both (seperate) endorsements. So by taking the exam for one you have also taken an exam that includes all the stuff you have to be tested on for the other (this is how Mate 500 or 1600 goes to 3rd Mate without a test, and 3rd Mate to 2nd Mate).
[QUOTE=bunker305;118226]…so again how does a 500 ton ticket magically grow? [/QUOTE]
See above. The DDE endorsement DOESN’T “GROW.” DDE and Chief Engineer (OSV) are entirely different and separate endorsements.
[QUOTE=bunker305;118226]…And if it does not make your ticket magically grow, can someone, only holding a DDE, go get a job on an offshore supply vessel as an licensed engineer that is over 500grt without the chief osv add on? [/QUOTE]
NO.
