FENNICA Damaged
Piss poor seamanship, piss poor sounding equipment and piss poor planning.
That is true. You never know where you’ll find a pinnacle. Maybe even on the West side, but the area in question is shoal water and more likely to conceal uncharted dangers to navigation.
[QUOTE=lm1883;165653]If that is the case, and poor charting is endemic in Alaska where is it safe to sail? They could have found an uncharted spot W of the island, then what would the conversation look like? You make the decisions with relevant materials and then go with it. By your definition it would be poor seamanship to sail anywhere in Alaska because of poor charts. I think that is a little off base.[/QUOTE]
In this case it is poor seamanship. Yes, the same thing could have happened west of Hog Island but the odds of that would be much lower than the eastern transit. They took a needless chance, thus poor seamanship.
Hansen’s Handbook
Generally the prudent mariner would avoid shoal areas unless he had local knowledge. The saying is “I don’t know where all the rocks in Alaska are but I know where there not”, meaning the regular routes. If deep water is an option it’s the best bet.
[QUOTE=lm1883;165662]Well I guess I’ll have to be in the minority opinion then. They grounded on an uncharted obstruction in an area with more than sufficient water charted for a safe transit. Would it have been better had they have went west of the Island? Maybe, but the application of poor seamanship does not apply here, it simply doesn’t. It’s a bad break. Remember that when you have yours.[/QUOTE]
Well, what you’re saying does raise a good point, which is the quick blame culture in our industry. We get enough of that from the regulatory side.
That said, I still maintain that, in this case, they helped to make their bad break. To me, seamanship means you try to put all the odds in your favor as much as possible, which in this case means it would have been the more prudent move to go west of Hog Island. I think that’s been just about beaten to death. But yes, you’re probably correct in that this doesn’t rise to the level of criminal by any stretch.
[QUOTE=Kennebec Captain;165664]
Generally the prudent mariner would avoid shoal areas unless he had local knowledge. The saying is “I don’t know where all the rocks in Alaska are but I know where there not”, meaning the regular routes. If deep water is an option it’s the best bet.[/QUOTE]
Well, thank heavens they had a mandated Alaska Marine Pilot with local knowledge onboard then! This is a regular route and I don’t think the FENNICA was arm twisting the local marine pilot in making the transit multiple times (much less Shell). I have been monitoring vessels crossing that area since this thread began.
It certainly would have been more prudent to avoid the blue area representing shoal. That does not equate to negligence because the master did not throw the pilot off the bridge each time they did. if it was indeed a negligent approach, I’d offer that in this situation, one could make a case that ‘mandatory’ state pilotage actually made this operation less safe. If only the foreign crew had relied on their own judgement instead of a local, maybe they would have used their lack of knowledge to ensure a more prudent route and avoided the shoal.
The blame game is an annoying fixture of real-time info the digital age provides. And it’s awesome that we can get such info. But, it forces us to take a measured view. All this data enables a rush to judgement. In this case, I’d encourage everyone to reserve judgment until the Alaska Marine Board of Pilots release their own investigation results as required by Alaska regulations (if they ever do!). Ditto for the CG investigation which would, I hope, involve interviews, evaluate functionality of nav safety kit and whether they were able to obtain VDR and echo sounder history data post-incident. Regrettably, no one in CG can assign blame and take the pilot’s license–they enjoy an enviable lack of liability. But there should be some careful oversight of the pilot’s actions in carrying out the state regulated practice not to mention the Board’s own involvement by publishing port information, training and approving pilots… I would be asking the Alaska State Marine Board for any and all incident reports involving vessels in that area to see if the Board itself ignored warning instead of the immediate tracing of responsibility of this incident to Shell as a reflex.
[QUOTE=Jamesbrown;165667]Well, thank heavens they had a mandated Alaska Marine Pilot with local knowledge onboard then! This is a regular route and I don’t think the FENNICA was arm twisting the local marine pilot in making the transit multiple times (much less Shell). I have been monitoring vessels crossing that area since this thread began.
The blame game is an annoying fixture of real-time info the digital age provides. And it’s awesome that we can get such info. But, it forces us to take a measured view. All this data enables a rush to judgement. In this case, I’d encourage everyone to reserve judgment until the Alaska Marine Board of Pilots release their own investigation results as required by Alaska regulations (if they ever do!). Ditto for the CG investigation which would, I hope, involve interviews, evaluate functionality of nav safety kit and whether they were able to obtain VDR and echo sounder history data post-incident. Regrettably, no one in CG can assign blame and take the pilot’s license–they enjoy an enviable lack of liability. But there should be some careful oversight of the pilot’s actions in carrying out the state regulated practice not to mention the Board’s own involvement by publishing port information, training and approving pilots… I would be asking the Alaska State Marine Board for any and all incident reports involving vessels in that area to see if the Board itself ignored warning instead of the immediate tracing of responsibility of this incident to Shell as a reflex.[/QUOTE]
For my part I"ve no intrest in the pilots negligence or whatever. If not for the Actic drilling this incident would not be a big deal.
The angle here is that one of the findings from the Kulluk grounding was that Shell needed to keep closer tabs on contractors. This incident makes it appear that Shell has not improved or perhaps cannot improve their operation.
If this case turns out to be pilot error or if it was just insufficient safety margins the issue would be what procedures etc did the crew have to defend the vessel against groundings and/or navigation errors by the pilot?
It’s a bit of a stretch but because this icebreaker is a valuable asset Shell could reduce this risk by providing the deck officers with some guidance with regards to voyage plans, no-go areas and minimum required UKC for the transit to the Arctic.
[QUOTE=Kennebec Captain;165675]For my part I"ve no intrest in the pilots negligence or whatever. If not for the Actic drilling this incident would not be a big deal.
It’s a bit of a stretch but because this icebreaker is a valuable asset Shell could reduce this risk by providing the deck officers with some guidance with regards to voyage plans, no-go areas and minimum required UKC for the transit to the Arctic.[/QUOTE]
“No interest in pilot negligence or whatever?” So, this only means anything to you as an opportunity to find fault with Shell, regardless of the determination of actual fault, reasonable liability, recommendations for improvement of marine safety or anything? You’re only interested in reading any findings with a view to how Shell alone failed and evince a personal determination to find and frame any debate along those lines? Maybe Shell actually did have such procedures, but until there’s actually an investigation, it’s not appropriate to jump to conclusions whateve one’s personal bias.
Yea but ultimately there’s no such thing as pilot error, ever. The liability for safe navigation is still on the Master or Mate, and ultimately the company for setting the safe practices or hiring the right people.
I can’t believe shell hasn’t paid someone $250,000 to look at some charts and highlight/shade areas and lay down some routes to issue to their fleet as guidance. Ideally in the way the world works this would be a green academy grad with no experience, but you’d think they would have a “navigation analyst” verifying every voyage plan. You see how some oil majors freak about safety glasses and ear plugs, but not navigation!
for those who like the visual or more technical side of things, I just stumbled across this post and survey image from the NOAA vessel that did the survey:
[QUOTE=Jamesbrown;165684]“No interest in pilot negligence or whatever?” So, this only means anything to you as an opportunity to find fault with Shell, regardless of the determination of actual fault, reasonable liability, recommendations for improvement of marine safety or anything? You’re only interested in reading any findings with a view to how Shell alone failed and evince a personal determination to find and frame any debate along those lines? Maybe Shell actually did have such procedures, but until there’s actually an investigation, it’s not appropriate to jump to conclusions whateve one’s personal bias.[/QUOTE]
Not intrested in negligence in the legal sense. That’s mostly about finding a scapegoat to advance politcal careers and for public consumption. I am strongly opposed to the criminalizaion of the mariner. Good article here about the Cosco Busan that reflects my views of legal system
My intrests are seamanship, navigation, decision making, procedures, error trapping.
Question here is, as far as I’m concerned; what can be done to reduce the risk of the crew striking bottom? My view is that improvements in the navigation planning process is an effective way to reduce risk.
That would lead to the question of if Shell is capable of running a safe operation or not. I think the appearance is that they cannot.
[QUOTE=Drill Bill;165703]for those who like the visual or more technical side of things, I just stumbled across this post and survey image from the NOAA vessel that did the survey:
Many navigators never consider the qualify of the chart bottom survey. This was an issue several years ago when a small cruise ship in the Antarctica struck a rock. I forget the details but basically the vessel’s defense was that the soundings in the area were greater then the vessel draft. It was then pointed out that the Antarctica was a poorly surveyed area and the UKC being used were not adequate.
There are methods to evaluate the quality of the survey, for example with lead-line surveys the distance between soundings is a clue.
Evidently the idea that a prudent mariner should not 'test the chart" in Alaskan waters when deep water are nearby is a controversial concept here but having spent most of the first 15 years of my career in Alaskan waters that idea is deeply ingrained.
It should have been obvious to the pilots and FENNICA that the east side of Hog Island was not a good place to be. It’s always been obvious to me.
To a large extent that is asking Shell to provide information that does not exist.
The licensed pilots know nothing about the Arctic because they have never been north of Nome. Nor are there any licensed pilots for the Arctic.
After several years of operating in the Alaskan Arctic, FENNICA already has a lot of local knowledge and experience. In fact, no one else (except NORDICA) has experience operating a vessel of that large size in the Alaskan Arctic. The only other people with any significant Alaska Arctic experience are the tugboat guys, and the Natives.
The Arctic is poorly charted and many coastal areas have never been charged at all. However there are no known, but uncharted, shoals near the drill sites or the deep water routes available between the drill sites and Dutch Harbor.
Except for Diomede Island, the Arctic does not look anything like the Aleutians. It looks more like the Outter Banks of the Carolinas. It’s deep enough with no hazards offshore. The problem is closely approaching the coast. The coast is shallow and mostly uncharted with sand ridges that shift with the winter ice. The approaches to many villages are obstructed by dual sand ridges just offshore the barrier islands. But Shell has no reason to go anywhere near the shallow coast. It’s Chukchi Sea drill site is 70 miles offshore with deep water everywhere on the way to the Bering Strait. The Bering Sea is reasonably well charted, but charts are less reliable close to shore.
There is shelter from northerly and easterly winds on the south side of the spit at Point Hope in about 10 to 15 fathoms, but other than that, there is no other good place and no good reason for Shell vessels to approach the Arctic Coast.
Good post tugsailor, intresting info.
FENNICA crew sounds like they have lots of good experties in the Arctic. Very valuable and hard to aquire.
However they got knocked out of action in Dutch harbor, Arctic experience not much help, about 50% of grounding occur when the pilot is aboard, It’s a very real risk that has to be taken into acccount
As an aside to all the interesting speculation and propaganda in this thread, you may be interested to know that in Sweden (another country with a lot of uncharted rocks) if your vessel hits an unnamed rock and sinks you will be offered the opportunity to have that rock given the name of your vessel on charts.
They didn’t sink but I wonder if the caption Finnica Reef will appear on the updated version of the Hog Island chart.
The spokesman for the pilots is saying here that the least depth for this transit was 45 feet. They likley think of that passge as being 42 feet.
The low spot is that row of 7 fm soundings cannot be avoided. That’s 42 ft+ 3 for the tide = 45 feet.
Seems like he is assuming that that FENNICA would have gone around that 5 1/2 fm shoal.
The Coast Guard called the Alaska Marine Pilots group based in Dutch Harbor late Wednesday to provide some information information the shoal, said information Entenmann, president of the group’s Western Alaska region.
A sea depth that was supposed to be about 45 feet in that area is now 21 feet shallower than previously thought, he said.[
[QUOTE=Kennebec Captain;165786]The spokesman for the pilots is saying here that the least depth for this transit was 45 feet. They likley think of that passge as being 42 feet.
[/QUOTE]
As far as I’m concerned that track goes right over the 5 1/4 fathom mark.
I can’t see why they ran through shoal water anyway.
there was also the guys who operated the Kulluk’s ice class ahts vessels in the Canadian arctic for years not sure what nationality those crews were my guess is not Canadian though.
[QUOTE=tugsailor;165119]FENNICA is at Magone Marine in Dutch Harbor with a “small hull breach.”
Would someone in Dutch please post pictures?[/QUOTE]
here’s some photos I took in Dutch Harbor last week with one of the Fennica
