[QUOTE=bnhpr;34777]Again, hangoff is what you do during an EDS due to loss of position, not a well control issue. There should be no reason to EDS for a kick or well control issue. It’s a last resort. No win scenarion, to the point where its rarely even discussed (this will change)
To shear, it doesn’t really matter if your hung off or not (unless you hit a tooljoint…oops) The hangoff just helps you retrieve the fish.
On the last 3 rigs I’ve worked on, the eds sequence includes automatic pickup of the drawworks after shearing. This is so you do not drag the fish out of the hole, and damage profiles, stack etc.
The standing joke is, how will the drawworks pull up if you lose power? In the days of compensators, you had hydraulic lift. With AHD’s blackout means there is no heave compensator!
Closing the annular is a good idea if you have time (slow), so you do not lose the oil based mud in the riser…as an environmental issue.[/QUOTE]
I was on a rig one time when the driller accidentally engaged the shears instead of closing the annular. We had just set a packer & were going to test the annulus. Anyway, he got it open before it completley cut the pipe. From what I’ve seen, it wouldn’t be easy to fish after shearing because it doesn’t make a claen cut. It mashed the pipe & cut it half into before he got it opened. The other issue I would have with hanging off before shearing is with the weight stacked onto a set of slips or hanging rams, I believe it doesn’t give the pipe anywhere to be displced. i have cut a lot of pipe & casing & the best way to cut it is with weight hanging off, because you get assistance from the weight hanging. I liken it to trying to cut a rope & only holding one end of the rope. I have some other questions for you & didn’t mean to irritate you yesterday. I was just giving my opinion on this operation.
On the rams is the hanging ram expected to hold pressure? because I would not like to trust my life on a ram expecting it to hold say 9000 PSI & 300k hanging weight. I also have heard a lot made about the annular. I would not want to stake my life on an annular holding 9000PSI.
I have read your posts on the BOP on DWH. I agree with you that there is no way every part of it malfunctioned. I am wondering if you think it is possible/probable that it may not have malfunctioned at all. I have believed this to be a possibility all along. that is why I have not come down on TO nearly as hard as BP.
I still say those ROV operators are some bad boys. So far they’re the only ones that can seem to get anything done since this mess happened.
