[QUOTE=dell;36846]Alcor,
Re your #2964: alvis was summarizing this: http://www.theoildrum.com/node/6593/648967 Now, is that rubbish, or not? Is the likely outcome, at this point, what dougr says:
"What is likely to happen now?
"Well…none of what is likely to happen is good, in fact…it’s about as bad as it gets. I am convinced the erosion and compromising of the entire system is accelerating and attacking more key structural areas of the well, the blow out preventer and surrounding strata holding it all up and together. This is evidenced by the tilt of the blow out preventer and the erosion which has exposed the well head connection. What eventually will happen is that the blow out preventer will literally tip over if they do not run supports to it as the currents push on it. I suspect they will run those supports as cables tied to anchors very soon, if they don’t, they are inviting disaster that much sooner.
"Eventually even that will be futile as the well casings cannot support the weight of the massive system above with out the cement bond to the earth and that bond is being eroded away. When enough is eroded away the casings will buckle and the BOP will collapse the well. If and when you begin to see oil and gas coming up around the well area from under the BOP? or the area around the well head connection and casing sinking more and more rapidly? …it won’t be too long after that the entire system fails. BP must be aware of this, they are mapping the sea floor sonically and that is not a mere exercise. Our Gov’t must be well aware too, they just are not telling us.
“All of these things lead to only one place, a fully wide open well bore directly to the oil deposit…after that, it goes into the realm of “the worst things you can think of” The well may come completely apart as the inner liners fail. There is still a very long drill string in the well, that could literally come flying out…as I said…all the worst things you can think of are a possibility, but the very least damaging outcome as bad as it is, is that we are stuck with a wide open gusher blowing out 150,000 barrels a day of raw oil or more.”
If not, why not? dougr’s piece is very well argued, and seemingly, well substantiated. I would expect a response, if your answer is negative, of equal quality.[/QUOTE]
Don’t expect him to answer. He never answers a direct question that can be debated & he will never back up his points with fruther points. He will instead ask why you have so much time to debate him or else try to throw the matter into another subject like the guilt of the MMS or the company man or TO.
