ATB Quandry? Or More justification for oversight and Government jobs?
[QUOTE=mtskier;109638]Crowley is apparently going to start sending ATB’s to the LOOP terminal. The Mooring Masters are voicing their concerns about the coupling while on the mooring. I don’t have ATB time, can any of you that do address moving down the notch ladder as the barge is pumped off while at an offshore mooring? Thanks![/QUOTE]
Intercon has an option for lightering mode on the newer systems.The helmets are rotated 90 deg. The pins can be partially retracted to slide up and down as needed. The manual says you can push in a 6’ seas in lightering mode on the 72 inch pins. Probably more on the bigger units.
