From the NEVEN website:
During the melting season I’m writing (bi-)weekly updates on the current situation with regards to Arctic sea ice (ASI). Central to these updates are the daily IJIS sea ice extent (SIE) and Cryosphere Today sea ice area (SIA) numbers, which I compare to data from the 2005-2011 period (NSIDC has a good explanation of sea ice extent and area in their FAQ). I also look at other things like regional sea ice area, compactness, temperature and weather forecasts, anything that can be of particular interest.
Check out the Arctic Sea Ice Graphs website for
daily updated graphs, maps and live webcam images.
August 25th 2012
I apologize for having provided so little analysis lately, but things are moving so fast that analysis can’t keep up. Now I know what an IPCC regional model for the Arctic must feel like.
Basically, I’m at a loss for words, and not just because my jaw has dropped and won’t go back up as long as I’m looking at the graphs. I’m also at a loss - and I have already said it a couple of times this year - because I just don’t know what to expect any longer. I had a very steep learning curve in the past two years. We all did. But it feels as if everything I’ve learned has become obsolete. As if you’ve learned to play the guitar a bit in two years’ time, and then all of a sudden have to play a xylophone. Will trend lines go even lower, or will the remaining ice pack with its edges so close to the North Pole start to freeze up?
Basically I have nothing to offer right now except short posts when yet another of those record dominoes has fallen. Hopefully I can come up with some useful post-melting season analysis when I return from a two-week holiday.
I’m at a loss at this loss. The 2007 record that stunned everyone, gets shattered without 2007 weather conditions. The ice is thin. PIOMAS was/is right.
Sea ice extent (SIE)
WindSat or no WindSat, the 2012 trendline on the IJIS SIE graph has dropped like a rock:
IJISSIE20120824
I had to adjust the Y-axis on this graph already once (compared to the one in the last ASI update), and it looks like I’ll have to adjust it again. I already announced the new IJIS SIE record minimum yesterday, although it was based on the preliminary number. But after the revision the record is still standing and IJIS still hasn’t stopped producing century breaks.
The current difference between 2012 and other years (without the unrealistic last data point that gets revised upwards) is as follows:
Continue reading “ASI 2012 update 10: (wh)at a loss” »
Posted by Neven on August 25, 2012 at 22:39 in Air Temperature, Arctic Basin, Arctic storms, ASI update 2012, Atmospheric Pressure, CAPIE/compactness, Cryosphere Today, DMI, IARC-JAXA (IJIS), Ice extent and area, SST, Weather forecast | Permalink | Comments (19)
Reblog (0) Digg This Save to del.icio.us
Record dominoes 8: NSIDC daily sea ice extent
There are several scientific organisations that keep an eye on the Arctic sea ice cover and put out graphs to inform us of the amount of ice that is left. You can see most, if not all, of them on the ASI Graphs webpage. I expect the record on most of these graphs to be broken in weeks to come.
The daily sea ice extent graph of the National Snow & Ice Data Center in Boulder, Colorado, one of the foremost and best-known organizations observing the Arctic, is showing a new record. Actually, the graph went crazy and is showing new record year 2012 only (will be fixed soon, I’m sure; edit: smart crandles says “it performs exactly what was asked i.e. display current year and year with the record low.”):N_stddev_timeseries
Edit 2: the graph has been fixed and updated, so I have made an animation that shows how the trend line dropped from the Arctic storm onwards:NSIDC2
But we have the numbers this time, because NSIDC decided - kudos to them - to release their daily numbers (hat-tip to Larry Hamilton):
Continue reading “Record dominoes 8: NSIDC daily sea ice extent” »
Posted by Neven on August 25, 2012 at 17:17 in Ice extent and area, NSIDC, Records | Permalink | Comments (74)
Record dominoes 7: Arctic ROOS sea ice extent
This used to be the last bastion of fake skeptics who cannot come to terms with what is happening in the Arctic and have to keep misleading till the bitter end (über-conservative IMS is now providing them refuge, like a cardboard box provided shelter to a Pakistani family in 2010’s monsoon that wouldn’t stop), but Arctic ROOS sea ice extent has fallen too:Ssmi_ice_ext
Have to rush now, another big domino has fallen: NSIDC daily sea ice extent.
Posted by Neven on August 25, 2012 at 17:04 in Ice extent and area, Records | Permalink | Comments (5)
Record dominoes 6: IJIS sea ice extent
After Uni Bremen extent, Arctic ROOS area, Cryosphere Today sea ice area, DMI sea ice extent and CT Arctic Basin SIA, another big domino has fallen, one of the most popular graphs in recent years, mostly because they have downloadable daily updated data: IJIS sea ice extent.
Sea_Ice_Extent
Here’s how the graph I use for ASI updates is looking right now:
IJISSIE20120824prelim
The 2012 has plunged below all previous minimums, but I have to add the caveat that this is based on a preliminary data point for August 24th, which will be revised tomorrow. It needs to be revised upwards by 66 thousand square km for this record not to remain standing. Even if this happens, the record will almost certainly be broken tomorrow.
Here are the numbers for the IJIS SIE minimums in the 2005-2012 period:
2005: 5.315 million square km
2006: 5.781 million square km
2007: 4.255 million square km
2008: 4.715 million square km
2009: 5.250 million square km
2010: 4.814 million square km
2011: 4.527 million square km
2012: 4.189 million square km (and running)
Another caveat is that the IARC-JAXA Information System (IJIS) - an international collaboration between the International Arctic Research Center (IARC) in corporation with the Japan Aerospace Exploration Agency (JAXA) - has switched from the AMSR-E to the WindSat sensor, when AMSR-E stopped functioning last year. WindSat isn’t as sophisticated as AMSR-E, so this could cause slight inconsistencies between the yearly numbers.
However, it seems that IJIS is soon switching to ASMR-2, the Advanced Microwave Scanning Radiometer 2, that is similar to predecessor ASMR-E, but better. All data will be consistent again when that happens. More on that later.
Next up is NSIDC daily sea ice extent or Arctic ROOS sea ice extent…
Posted by Neven on August 24, 2012 at 12:59 in IARC-JAXA (IJIS), Ice extent and area, Records | Permalink | Comments (182)
Peeking through the clouds 5
Commenter dabize has sent me the latest ‘declouded’ version of the False-Colour Composite images Environment Canada makes of the LANCE-MODIS satellite images. They give us an excellent view of week to week changes that are blocked by cloudy conditions in the Arctic.
Changes in the ice pack really stand out, but also keep an eye on the Canadian Archipelago and Northwest Passage, where in situ melting is jaw-dropping this year:
EC MODIS 5
Posted by Neven on August 23, 2012 at 11:59 | Permalink | Comments (58)
Record dominoes 5: Arctic Basin sea ice area
This is just a regional sea ice area graph put out by Cryosphere Today, but it happens to be the most important regional graph out there. This is the place where the last ice is expected to be if and when the Arctic is approaching an ice-free state. On this graph we clearly see the minimums for all the years in the satellite period (click for a larger version):Region.all.anom.region.1
The data on this graph has been the source of a recurrent discussion on the ASI blog, revolving around the question: Was a plateau of around 2.3 million square km reached in 2007? This year might give us a clue. The trend line has already surpassed 2.25 million square km, but maybe things will level off now. Or it could dip below 2 million square km. We’ll know in a few weeks, but either way, this is yet another record that was broken this year.
Posted by Neven on August 23, 2012 at 04:37 in Arctic Basin, Cryosphere Today, Ice extent and area, Records | Permalink | Comments (137)
Record dominoes 4: DMI sea ice extent
If I were addicted to records, I’d have OD-ed by now. Out of the approximately 9 sea ice extent and area graphs on the ASI Graphs page, 4 have broken their record so far. After Uni Bremen extent, Arctic ROOS area, Cryosphere Today sea ice area (big one), we have a new sea ice domino: Danish Meteorological Institute sea ice extent. DMI uses a 30% threshold instead of the more habitual 15% (meaning every grid cell containing a concentration higher than 30% gets counted for total extent).
Icecover_current16
Larry Hamilton sent me graphs and numbers:
Sea_ice_DMI_this_date2
Year | min(totaldmi)
2005 | 4.138
2006 | 4.336
2007 | 3.0523
2008 | 3.4441
2009 | 3.8455
2010 | 3.6416
2011 | 3.3207
2012 | 3.0311
Sea_ice_DMI_min_to_date
Thanks, Larry!
As a bonus I’ve made an animation of the daily DMI graphs from the moment that cylcone hit to the new minimum:
Continue reading “Record dominoes 4: DMI sea ice extent” »
Posted by Neven on August 22, 2012 at 10:02 in DMI, Ice extent and area, Records | Permalink | Comments (87)
