Sad situation a lot a lot of good people lost. In some ways the story reminds me of the Edmund Fitzgerald or the Derbyshire.
Pity its not the NTSB leading this investigation. Trying to find someone to blame isn’t going to help prevent a future occurrence.
We really don’t know much. Ships lost, Crew Lost, No VDR a few emails and position reports beyond this its guessing.
What the company says is absolutely true. Masters is responsible and has the authority. Just is the way it is. Was there pressure? There is always pleasure. Just is the way it is. Did the pressure make a difference. You will need a physic to find out. The voice recordings on the VDR may give some clue. If they are retrieved. Unlikely there will be any clear statement about pressure. There may be a recording of the bridge team discussing there options.
The thing about the pressure is. Its way to subtle to be recorded. Often its just imagined. A schedule is pressure just because it exists. The cost of delays is pressure. Decisions have to be justified and explained. More pressure. Ocean routing and weather services say go this way more pressure. Easy for them to say they ain’t on the boat. Often they are no help just more pressure. In any case they have no responsibility. Only the Master has responsibility. In the end its up to him or her, just the way it is.
Sometimes the greatest pressure is peer pressure. Sometimes even greater the pressure he puts on himself or just imagines exists.
How does this affect the Master? Depends on the Master, the Manager ashore. all of it intangible.
When you get it right everyone is happy.
The ship gets bust up, The cargo gets bust up, The crew or passengers get bust up. The Dock gets bust up. Nobody thanks you for trying when you get it wrong.
Why did he go the way he went? If the VDR gets recovered there might be some clue.
He probably was confident enough in his ship and crew to believe it would all be OK. He may have had it work out OK before.
Over estimated the ship and underestimated the weather? The loss of power. When did that happen? It probably changed everything.
Dead ship, no power, worsening weather, How bad was the problem? How hard to fix? Pretty dam hard in a ship beam on or bow down in the Unnavigable circle.
Why is it called the Unnavigable circle?
Cause if you try to run before the wind or heave to or loose power the wind blows you in towards the its center.
The eye is just plain bad.
Within 50 is just plain bad, Worse when the Squalls hit.
50 to 75 Not a good place to be, Worse when the Squalls hit. Nasty but a well found ship should be able to handle.
75 to 100 Just another bad day at sea.
100 plus Bu#$%r all to a big ship.
Some big ship RADARS have a 48 mile range some 72 or even 96. for the most part the horizon is so much less these ranges are about as much use as tits on a bull. If you are near a TRS you can often pick up the squall lines and even the eye may be track able.
His plan may not have been so bad if the ship hadn’t lost power. We might never have heard of him or his ship. As plans go it wasn’t a good one. Real easy to say with hindsight from the comfort of an armchair.
There but for the Grace of God go I. I’ve made some good plans and some not so good and a couple of downright bad ones. They all worked out OK in the End.
This guy paid with his life and his crews. Unfortunately he will be vilified. Just the way it is.
