Swing check valve on fuel manifold
I’ve run into a problem I need some insight on.
I run a boat with 3 main engines, (MTU 12V 2000 series) fed by a 1-1/2" fuel pipe which feeds a manifold with separate shut off valves for each engine.
Forward of the manifold is a bronze swing check valve. Last week, the swing portion failed, and subsequently starved the engines for fuel. After continually knocking the valve with a hammer, we made it back to the dock. I promptly removed the valve, and replaced it with a new one, minus the swing check portion. Essentially a coupling with nothing to restrict the flow of fuel.
I understand the purpose of having the valve in place. It would prevent fuel from going back into the day tank, and having the engines lose their prime when not being run. Otherwise, what purpose does the check valve serve? It seems like a dangerous item to have in the fuel line. Are there regulations that require a check valve in the fuel line? I’ve worked on several vessels, and this is a first.
[QUOTE=Swampfox;155221]I’ve run into a problem I need some insight on.
I understand the purpose of having the valve in place. It would prevent fuel from going back into the day tank, and having the engines lose their prime when not being run. Otherwise, what purpose does the check valve serve? It seems like a dangerous item to have in the fuel line. Are there regulations that require a check valve in the fuel line? I’ve worked on several vessels, and this is a first.[/QUOTE]
I do know from past experience, if your tanks are belly tanks the swing check is helpful because of the engines being higher than the fuel tanks. If the tanks are higher than the engines gravity is on your side until/if you allow the level to drop below the engines.
Should have replaced it with a lift check instead of converting a good valve into the world’s most expensive pipe nipple.
What Steamer said is correct.
Thanks guys. Learn something new everyday.
I’m dealing with BSP thread, so I had to make due with what I could get my hands on at the time.
