of course the article speaks of these two mega-majors globally but says little regarding their US projects which we are mostly concerned with here.
[B]Exxon, Shell’s Spending Patterns May Help Them Through Oil Price Drop
[/B]
Ron Bousso & Dmitry ZhdannikovTuesday, March 10, 2015
LONDON, March 10 (Reuters) - The world’s two biggest oil firms, Exxon Mobil Corp and Royal Dutch Shell, may withstand the oil price collapse better than their rivals because they are closer to finishing expensive investment projects while others must keep spending.
The near halving of oil prices since June is likely to send all the biggest listed oil companies into negative cash flow this year, and has sparked a rush to cut costs across the sector as a result. But depending on where they are in their spending cycles, some companies are finding those cuts easier to make than others.
“Both (Exxon and Shell) had already entered a lower spending phase, with major projects reaching completion and coming on stream over the next two years,” Moody’s rating company said in a report.
Exxon started eight major oil and gas production projects last year in locations ranging from Papua New Guinea to the Gulf of Mexico and Abu Dhabi.
Shell started four big production start-ups last year in the Cardamom and Mars B oil fields in the Gulf of Mexico as well as other oil fields in Nigeria and Malaysia.
As a result Exxon, the world’s biggest publicly traded oil company, was able to cut its 2015 project spending by 11 percent to around $34 billion without significant impact on its production. Shell, the second-largest, opted for a $15 billion cut over the next three years and maintained its 2015 capital spending at $35 billion which will also not affect its output.
Chevron and Total, on the other hand, are both in the midst of large project spending cycles, and will have to tap into more debt in order to stay afloat, Moody’s said.
Elsewhere BP, despite cutting costs and jobs and freezing salaries, still faces sizeable outgoings related to its 2010 Gulf of Mexico oil spill fine and its stake in Russian oil champion Rosneft.
Most big oil firms announced cuts of 10 to 15 percent to their 2015 budgets versus last year. Some suspended share buybacks, revived dividend payment via company stock, known as scrip shares, and maintained dividends flat in order to boost cashflows.
While all companies are expected to keep paying high dividends by increasing borrowing, Anglo-Dutch Shell and Texas-based Exxon appear to be most able to cover both spending and dividend payouts if oil prices stay at their current $60 a barrel.
They are also likely to be able to pick up bargain assets, while the price collapse shakes the sector out.
“Those who have stronger balance sheets would be able to acquire more assets in the downturn, for example distressed and cheap U.S. shale producers,” said Kirill Pyshkin who helps manage over $400 million in global and U.S. equity funds at Mirabaud Asset Management in London, including shares in Shell.
Pyshkin noted too: “If oil prices recover they won’t have to sacrifice their growth budgets and hence will be growing faster than peers in future.”
Lower BreakevenExxon and Shell also lead the rest of the pack in terms of where their cashflow breaks even. They can survive on a much lower price of oil to cover project spending, operating costs and dividend payments.
According to analysts at Jefferies, Shell and Exxon both have 2015 breakevens of around $75 to $80 a barrel.
While that’s still significantly higher than the average 2015 Brent price of around $56 a barrel, it’s healthier than Chevron, BP and Eni’s breakevens which Jefferies forecast at around $95, $100 and $120 a barrel respectively.
For some however, while Exxon is a safe investment, its dividend is relatively low compared to its peers and its shares offer little upside because of the steady course the firm is now on. Other peers and smaller companies offer better returns.
“Although it (Exxon) retains significant defensive strengths should oil prices dip again, we think the market is now beginning to deploy its investment dollars in higher risk plays,” BMO Capital Markets analyst Iain Reid wrote in a note to investors.
Reid’s key pick is Shell, which still has “plenty of firepower to deliver further upside via more aggressive restructuring”. Total, which is further behind in the spending cycle may however also offer higher returns for investors in the future, Reid added.
According to Reuters data, 15 out of 23 polled analysts are neutral on Exxon shares, while 5 rate it a “buy”. Shell is more attractive for analysts, with 10 out of 20 recommending a “buy” and 9 a “hold”.
Total remains the most robust stock, with 17 “buy”, 16 "hold and 2 “sell” recommendation.
Borrowing Up
All of the big oil firms are expected to see negative cash flows this year, according to Moody’s, and will turn to borrowing in order to cover costs.
All have indicated they would have no problem increasing borrowing this year, given their debt-to-equity ratios below 20 percent.
“The majors with their AA and AAA ratings still have access to attractive sources of funding. Their balance sheets have the capacity to absorb one or two years of low prices,” said Wood Mackenzie analyst Tom Ellacott.
likewise, it fails to mention one word about Shell’s overpriced arctic ambitions and if they plan to pour yet more billions into a place that they could never produce profitably from even if they do discover 10MM/bbl in the Chukchi Sea.
