While the names don’t match exactly (IMO 7826180 is Hua Jing 001, not Fu Jing 001), the deckhouse appears identical so it could as well be the same ship.
Lots of info in Polish (but luckily easily translated by Google Translate):
I know. I don’t have subscription either - had to search Google word-by-word to see the vessel name in the preview. However, I still wanted to include the original source even though it’s behind paywall.
Later I came across that Polish page which I read through Google Translate.
The sunken vessel, ‘Fujing 001’, with a crew of 30, was at an anti-typhoon anchorage in waters near Yangjiang in Guangdong when its anchor chain snapped.
“Anti-typhoon anchorage”, odd phrasing, presumably an anchorage considered to be typhoon haven.
Unless it was massively modified, though, HLV ZHEN HUA 20 differs substantially from our failed vehicle; in particular, the exhaust structure is behind the accommodation block, rather than in front and to the side as we’ve seen in these videos and images…
Yes that has been mentioned several times already.
She was recently converted to a Wind Turbine Installation Vessel (WTIV) (V = Vessel not Vehicle)
The bow was cut off, a large crane installed and no longer self-propelled. (IFAIK)
If the main engine is no longer in use there are no use for the large funnel she sported as a ship.
Here is a picture of the same vessel as tanker Sereno 2:
It is quite common to install new generators when making a major conversion and change of purpose, especially on older vessels.
If so, a new generator room may be constructed outside the old Eng.Rm., with new exhaust ducks to go with it. (as seen here)
The reason could be as simple as different roman spelling of the same Chinese signs.
(Pinyin vs. Traditional Romanized. I.e. Bejing vs. Peking)
PS> Fu Jing (傅菁) is also the name of a Chinese actress:
