[QUOTE=BruceHinton;34872]I’m new here, my search-fu is weak. So, I will be as brief as I can, thereafter I will read a lot and post only a little.
What is the minimum diameter of the riser flow column, starting at the four, (triple redundant?), shutoff valves I saw on a TV animation? What, comparatively, is the flow column size of the recovery pipe they are trying to affix. BTW, I hope the thing is heavy enough and backed up with enough mechanical power to set down on that turbulent blowout.
Has the possibility of explosives been thoroughly discussed in public? Seems it was dismissed early. I pondered a ring of downward directed charges plus one on top might collapse everything down to a sufficient depth to leave only minor leaks, until “relief holes”(-term?), could be deep enough to inject concrete into the original well hole.
These are only the thoughts of a spectator, -we may not know much about all this but we sure do speculate a lot! We have no expert advice to turn to, you see.
Bruce[/QUOTE]
Your “search fu” is actually non-existent.
If you search above in this thread (actually this very page of this very thread), there is a link that bnhpr supplied that describes every little bit of construction of the well. Or at least that part of construction that bp is sharing. However, it is very descriptive and gives all the information you are asking for. Be careful though, it actually requires you to [I]click on it, and read it[/I]. It also has been linked to on almost every single site that discusses this event
For the love of god. Again, this cockamamie idea has been debunked a thousand times on a hundred websites. But, once again, I will debunk it just for you (since you can’t bother to use google to find any of those thousands of threads that debunk this cockamamie idea).
a.). There is nothing TO blow up. What would you have them “blow up”? The casing? How would they get these explosives there? If they could get something in there, don’t you think cement would be better? So should they “blow” the seafloor? Do you understand what the seafloor is? Basically it is the consistency of custurd. What do you think they would accomplish by blowing up pudding with a steel pipe running through it? So, should they drill a well down and blow up the rock that starts thousands of feet down? Well, if they are running a well down (which they are already), why not just, uh, fill the blown out well with cement instead? Oh, wait, [I]that’s the plan![/I]
b.)Even if they 'blew it up" what would that accomplish? So what would they accomplish by exploding the casing? Wouldn’t they just have a bigger, exploded casing? How about exploding the pudding consistency sediments around the casing? You think that’s going to do jack shit, except maybe create more leaks in the casing? Ok, well, how about the rock above the formation, why not explode that? Gee, maybe because you could potentially create a whole area of fractures that would allow the oil and gas to just travel directly to the surface, it wouldn’t even need a well anymore, because now it can just go up all those nice new cracks you’ve created for it with your explosives.
c.) Then there is the real reason why this is not worth discussing, and that is that there is nobody in either bp or the government who is yet dumb enough to buy this as a “solution” that has any potential upside whatsoever.
d.) So, now that we have dispensed (for like the five thousandth time) with why this is just with the most base knowledge a clearly dumb idea, why don’t we talk about something constructive. For example, maybe we could send a shuttle up, and have it go so fast in the opposite direction to the earth’s orbit that the earth starts spinning backward, undoing time to where this even never happened in the first place? Can someone explain why that wouldn’t work? It seemed to work when Superman did it.
Now, does anybody want to know why we don’t just use a nuclear bomb “like the russians did”?
