[QUOTE=Brad Wehde;34613]G-Captain
TO ALL THE ENGINEERS AND SCIENTIST AT BP.
I have designed another device that will bring a hydraulic hose down into the well bore. My idea with this is to create gas hydrate in the well bore to plug it up.
Since BP likes a “Simple” approach to things, they might like this one. This is so simple and in front of their eyes. The problems with the domes was the “ice crystals”. You say (BP)… “we’ve learned a lot with our experiments” (you should have already known). Here is a simple solution and I will explain it in a simple way. When water mixes with the gas at that depth, the water molecules bond with the methane, forming “ice crystals”. Now you have just learned this in the last few weeks. This is why it plugged up your Simpson dome. Use what is against you to your advantage. Run water deep in the well bore.[U] As the water mixes with the methane, this forms ice and plugs the well bore[/U]. You know this works because it plugged your Simpson dome before. This gives you enough time to make repairs to the (BOP) either by removing the LMRP down to the collet connector and install a valve with a flange and then you can have a solid connection if you like to a tanker or drill ship if you still want some of that oil.
G-Captain I was the one that designed the retrofit bop device at http://www.wehdeinteractive.com/RetroFitBOP.html
I did not make a animation for this one yet.
I think this is a very simple solution, easy to build, cheap and will work.
Brad Wehde brad@wehdeinteractive.com[/QUOTE]
[ATTACH=CONFIG]898[/ATTACH]
[I]Methane hydrate phase diagram.[/I]
Notice the pressure line of [U]60,000 kilopascals[/U] because that is 8,702psi, the approximate pressure down at the root of the BOP as we are told by officials.[U] 81.5F = 27.5C[/U] and that is the “phase shift” threshold at that pressure.
methane hydrate: a large amount of [U]methane[/U] is trapped within a [U]crystal[/U] structure of water, forming a solid similar to [U]ice[/U].
[ATTACH=CONFIG]899[/ATTACH]
Geopressure/geothermal wells are those which produce extremely [U]high-pressure (7,000 psi) and high-temperature (149 °C) water[/U] which may contain hydrocarbons. The water becomes a rapidly expanding cloud of hot steam and vapours upon release to the atmosphere from a leak or rupture. [SIZE=3][FONT=Arial][SIZE=3]Extensive on-shore and offshore zones of geopressured water reservoirs are found in the Texas and [U]Louisiana Gulf Coast region[/U]. Energy in these reservoirs is present in the form of natural gas in solution, thermal energy, and hydraulic, energy. Reservoir depths generally vary from 5000 to 20,000 feet, with corresponding temperatures from below [U]200°F to above 300OF[/U]. Natural gas is presumed to exist at saturation levels in the reservoirs
[/SIZE][/FONT][/SIZE][U][SIZE=2]http://www.osti.gov/bridge/purl.cover.jsp;jsessionid=6E492A186796F63E045E0E7885CECDF0?purl=/886701-dj1WJH/[/SIZE][/U]
Once formed, hydrates can block pipeline and processing equipment. They are generally then removed by reducing the pressure, heating them, or dissolving them by chemical means (methanol is commonly used). Care must be taken to ensure that the removal of the hydrates is carefully controlled, because of the potential for the hydrate to undergo a phase transition from the solid hydrate to release water and gaseous methane at a high rate as the pressure is reduced. [U]The rapid release of methane gas in a closed system can result in a rapid increases in pressure[/U]. When drilling in oil and gas-bearing formations submerged in deep water, the reservoir gas may flow into the well bore and form gas hydrates due to the low temperatures and high pressures found during deep water drilling.
The gas hydrates may then flow upward with drilling mud or other discharged fluids. As they rise, the pressure in the [U]drill string[/U] decreases and the hydrates dissociate into gas and water. The rapid gas expansion ejects fluid from the well, reducing the pressure further, which leads to more hydrate dissociation and further fluid ejection. The resulting violent expulsion of fluid from the drill string is referred to [U]as a “kick”.[/U]
[U]I can see how the crystals form outside this pipe at 2C and 2240psi. But just injecting water into the 200-300F crude oil and gas at 8,700psi hydraulic is not gonna make ice happen in that pipe, by way of my understanding[/U]. Can you explain how this is accomplished?
The ice clog problem and resultant ‘kicks’ is why I produced this video a week ago. http://www.youtube.com/watch?v=fB2qgOAsOLo Conceptually, aside from structural design, I wish to be corrected in any number of ways, hoping somebody could tell me why this concept should not have been on standby, already designed for Horizon or others … I can think of 50 modifications of this theme of suction dredge in 10 minutes. I simply want this spill to END.
I started to make a new 10-minute YT video expressing the gravity of my concerns this evening … but it may be illegal to show the public on Youtube how bad this thing might be, IF it is not improved … I WISH THE BEST. I’m not yelling fire … yet.
