Cu Ni 90/10 pipe routed inside the water ballast tank
Dear Expert,
Kindly let us know the following questions answer,
  1. For Cu Ni 90/10 pipe routed inside the water ballast tank, so what type of joint is suitable & acceptable as per class rule.
  2. For Cu Ni 90/10 pipe flange and other material is NAB as per owner technical specification, let me know what is the reason there selection NAB materials for fittings?
Regards,
Mani.P
weld as to the first i imagine. the other you’ll have to find some ship yard guys!!
I can only think of Walter Sobchek right now. “You’re in over your head Mani”.
What class? Have you read the applicable section of their rules?
What system does the pipe belong to? Ballast fill / suction line that ends in tank? Or another system passing through the tank?
By NAB. Are you trying to say NiAlBr?
no, no, no…it’s
Hell, I can get you a toe by 3 o’clock this afternoon… with nail polish. These fucking amateurs…
