Question about forward peak
hello
i need good explination of the element “forepeak” .
and i need specialized documents about it for my project .
i did searched ,but i couldn’t found it
thank you
The front end of the hold in the angle of the bows of a ship.
http://www.oxforddictionaries.com/definition/english/forepeak
https://www.google.com/url?sa=t&source=web&rct=j&url=http://www.iacs.org.uk/document/public/Publications/Resolution_changes/PDF/UR_F44_Rev2_pdf1433.pdf&ved=0ahUKEwi8gLTNtd_KAhUBlA8KHU7_ASQ4ChAWCCQwBQ&usg=AFQjCNFiO-6ZFmCAnQGXjQ5JiPrjUS5LVA&sig2=dcTVlBKLsaTLQVHDWaJfrg
Fore peak is the compartment (typically a ballast tank) arranged forward of the collision bulkhead.
[QUOTE=Tups;178392]Fore peak is the compartment (typically a ballast tank) arranged forward of the collision bulkhead.[/QUOTE]
Or fresh water tank. . . .
[QUOTE=cmakin;178398]Or fresh water tank. . . .[/QUOTE]
Not when you’re designing a ship according to the USSR Sanitary Rules from 1984 :wink:
It might not be ‘Fresh’, but it’s still the ship’s ‘potable’ water.
[QUOTE=LI_Domer;178434]It might not be ‘Fresh’, but it’s still the ship’s ‘potable’ water.[/QUOTE]
What kind of vessels have such tank arrangement? I have never seen a fresh (potable) water tank in the forepeak - it’s always either dry tank or, more commonly, a ballast water tank.
As for the Russians, the still-valid Sanitary Rules forbid having the fresh/potable water tank against against shell or any other tank (apart from dry tank/cofferdam or another fresh water tank).
My apologies,I meant that as a joke. The forepeak tank is most commonly ballast.
[QUOTE=LI_Domer;178456]My apologies,I meant that as a joke. The forepeak tank is most commonly ballast.[/QUOTE]
No problem. I’m terribly bad at recognizing jokes. :smiley:
